Looks Like a Turbo Kit for C4's is Finally on the Way!
I'm not saying it can't be done, I'm just saying doing it is a major pain. You would basically have to get it to the engine compartment, bring it to the top of the engine to go over the suspension, steering rack, and crossmember, then go back down to get into the radiator shroud. Obviously this is all theoretical unless you have the kit sitting right infront of you to measure space.
But just because they found a way to do it on the C5 doesn't mean it can be done on a C4.
www.thor-racing.co.uk/Charge_Coolers-291.asp
Then you just have to find a small radiator and run water lines to the front.
Dyno was slow this winter obviosly, but it's crazy now. I have like 10 serious builds going on + the CNC to setup. I needed the CNC to build the molds for my carbon fiber parts and we'll be building all my billet parts in house from now on as well as anodizing and powdercoating. I had to quit school for this semster because quite frankly I cant fit anything more on my plate and you really need to pay attention in E.E. classes or your lost in a week. This is me at my shop all day and night=
Whatchu been up to man?
all things considered id say screw the intercooler and just run a good multi stage Water/meth injection system. For the weight and hassle involved (believe me) same power can be had at the expense of popping the hood every tank or two and dumping in a few bottles of the blue sause.
Could do something like this:
http://www.coolflow.com/intracooler/intercooler.htm
Put this in the trunk somewhere and Thor-racing unit in the back.
I would think it may be better to put all of this at the front so the air cools along the way and then even more at the intercooler. Maybe mount the pump and chiller where the battery is.
I bent them and welded them on. C4 Vert's are a bitch to do and keep the top workin with the rollbar. The two hoops were the comprimise on being able to use the S&W 8pt kit for the coupe and make it high enough to help prevent tall people from being decapitated in a rollover.
Bruce's turbo is a TV-85. It's T-6 based with a split tangential housing half blocked off.
If your Gt42 is a 4202 then you have a 75.xx mm inlet 102mm Od.compressor wheel w/ 82mm turbine wheel.
The Tv-85 has a 85mm inlet and a 130mm OD compressor with a 94(?)mm turbine wheel.
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Is this car seriously stock?
I don't know what my C4 dynos, but I don't think it makes 300 rwtq at 2k rpm.
Hope to have details in about two weeks. Here is some info on the LT1 F Body, we hope the info will be about the same. http://oi.b5z.net/i/u/1473169/i/pdfs...1_02_Final.pdf
Hey
I'm new at this turbo thing here (as it appears most corvette owners are) but I kind of would expect more than 394RWHP from a turbo.
I looked at superchargers and I am wondering what the differences are in them. I don't mean what's the differnce between a turbo and a supercharger but rather what's the difference in this package in terms of HP and realibility?
I see some people on here making 450-500+ RWHP with turbos granted for much more cost I'm sure but for me, if I were to invest 4000 dollars, I could get some awsome heads and be there.
I just put this out there because I feel like I'm missing something. It seems like much effort and cost for 394RWHP.
#33
Hey
For 4K you can get a pretty nice heads and cam package that will give you 400chp, a supercharger kit for 420chp, or a turbo kit that gives 400RWHP.
Its more a matter of choice and what you are looking for out of your car. For our engines 500rwhp is VERY tough to do even with a big stroker motor. You need the FI to do it.
If you are talking about the LSX engine, that's an entirely different beast. It responds very well to boost.
#34
Hey
#35
Hey
although out the box the kit doesn't seem to make much power, there will be lot of room left in the kit! taking the LS stuff, they normaly make 450 ishrwhp out the box, but the stock kit can go to about 550rwhp! also as said before, its easier to upgrade the turbo unit if you, and your motor, can take it.
thanks Chris.
#37
The LT1 car will be driven this week from AZ to OK where it will get it's final tune. The car will then be driven to and put on display at Bowling Green, KY for the ZR1/C4 Gathering which is the first week of May.
I'll post the dyno numbers after the final tune.
Cheers,
Ron
Cheers,
Ron
#38
Cheers,
Ron
Cheers,
Ron
#39
Right now here's the plan.
LT1 Car to OK sometime in the next few days (Jerry is driving it)
LT1 Tune
LT5 car to OK within the next week (Jerry is also driving that one)
LT5 Tune maybe...
Both cars driven from OK to Nashville Mon/Tue, ZR1 tuned or not. (Jerry and a friend)
Jerry picks me up Wed in Nashville 1530 hrs then we drive both cars to BG.
Option 2: I take delivery of my (possible) new Ruby Z in Nashville and all 3 of us drive north
#40
Jerry is going to BG.
LT1 Tune
LT5 Tune maybe...
LT1 Tune
LT5 Tune maybe...
I'll take option 2!
