Edelbrock LT4 intake pics
Got my LT4 intake from Scoggin Dickey today. (Thanks for the quick shipment!) I took a few pics. The gasket it the 12367777 LT4 gasket. Looks like it will need a little more porting. Looks like a nice piece. Hopefully It will dropped off at Morgantini's for porting and back to put on before the first points Challenge race at E-Town
didnt Edelbrock make an LT1 intake several years ago, with longer runners (11.5 inch i think)?
IIRC, the runners were "rolled" under, similar to an LS1 style. from the top, it didnt look very different than the stock intake.
I bought mine simply because I could not find a factory intake for less than $600 at the time. Since then I found one for $500 and bought it just so I could drive the car again. We'll see what this does for the prices of used LT4 intakes. The price and availability (now) are the main advantages for some folks.
How did they do on the inlet.....does it really matchup to 58mm???
So in addition the cost of a new intake, one should figure on the cost of port matching-----which I already did once on my stock manifold..
Like others will be waiting to hear your results..
Edit: Reviewed this and Edelbrock didn't say matched, they just stated this was the recommended gasket, (which I incorrectly interpreted as matched)
Scott
thge manifold is great for those who need an Lt4 manifold no doubt. Im not hating there. I just think for edelbrock to come out with a product like that.. they could have at least had a larger plenum or larger runners or longer runners (slightly), or a distributor hole in the back.... so many things... perhaps even small holes for nitrous kits... edelbrock needs to learn from what the ls guys have in the fast and other brand manifolds. How about a removeable top piece so porting can be done inside the main plenum.
edelbrock sucks the big one.
the manifold is great for those who need an Lt4 manifold no doubt. Im not hating there. I just think for edelbrock to come out with a product like that.. they could have at least had a larger plenum or larger runners or longer runners (slightly), or a distributor hole in the back.... so many things...
The inlet is 58mm. The picture is with a 58mm gasket, which you can see needs just a little touch up.
Like stated the factory intake also has EGR conections. I also thought it felt a bit heavier. Dave could you weight the factory one since mine is still on the car? I get 20pnd for the Edelbrock.
It is stated that it has .250 longer runners than stock. We'll see if it helps any or not at the track in a few weeks.
