factory stall speed
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
85-86 had the 2000 stall, then it dropped to around (I think) 1600 after that. The H-body guys were using those until they got scarce, then switched to the S10 converter which was rated at 2025 rpm...
Received 1,401 Likes
2026rpm for 85-86, which doesnt need to be changed unless you've done away with TPI.
yeah tpi is long gone, bought the car with out an engine, ideally I need a 2800 to 3200 to go best with my cam but the 2k should be somewhat decent temporarily. Thanks for the reply!
