1985 cig lighter
1985 cig lighter
My cigarette lighter doesnt work on my 1985 vette. Is there a fuse somewhere that is linked to this or is there something i can check to fix it. There is no power to it at all. Thanks,
Tyler
Tyler
Check the fuse marked as CTSY/CLK 15 AMP Fuse. Also if you go to this webpage I have posted the diagram from Helms
http://www.homeofstewarts.net/corvet...k/ctsy-clk.gif
Stewball
Stewball
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If that fuse was out your radio and interior lights wouldn't work.
More likely the plug just came loose from the back of the lighter housing. It can be tricky to install while putting the console plate back in. I'd check that first.
