85 throttle body cleaning
OK all
i just did a search and saw a lot of recomendations to clean the throttle body but didnt see any on how to clean it
i am having idle surges andi had a few poeple tell me that i need to clean the throttle body
is this a task anybody can do or should i take it to somebody
what is involved
does the throttle body need to be removed to clean or will running something like seafoam through it do the JOB
what is involved
St. Jude '03-'04-'05-'06-'07
You can do both ways....remove or in place... in place get some TB cleaner, high rev and clean, but best to remove, scrub, clean... Idle could also be the IAC needs to be cleaned and along with that the TPS will need to be reset... anyone can do this
Cruise-In II Veteran
Pick up a can of TB Cleaner (NOT Carb Cleaner) at Auto Zone.
Remove the MAF & TB bellows, open the throttle and wipe out the TB bore & blades. Some cotton swabs may help get into tight areas.
thanks all....afterreading what i posted i figured iwas gonna get ripped
i already knew how to clean while it was on i was looking at doing the full clean. like my repair manual says.
were is the IAC located
