What is Z51?
Received 1,401 Likes
In 86 it gets a quicker steering rack, 3.07 gears for A4, much stiffer springs, slightly stiffer shocks, different bushings, bigger sway bars, auxiliary fan, oil cooler, wider tires (9.5")
doesnt depend on the transmission in 86
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Someone mentioned different mufflers for the Z51 also. But the factory manual doesn't agree with this.
It does show different mufflers based on rear end ratio though, starting in 87.
Z51 depends a LOT on what year you're talking about.
Both sets of tips are functional, vs. only the (thinks hard) inner (?) tips on non Z51 vehicles. At least that is what we've always said. My original mufflers are LONG gone and the brain cells I had when I had them were overwritten eons ago too.
Location: Why are there squished peanut butter cups in my underware?
Standard mufflers vs Sport mufflers `87 through `91;
All verts had standard mufflers.
Coupes with 2.59 axle autos had standard mufflers. (single nozzle funtcional)
Coupes with 3.07 axle autos and manuals had sport mufflers. (dual nozzle funtcional)
A lot of `91 manual coupes received the standard mufflers. (Maybe the factory used all the sport and didn't bother getting more with the new LT1 style.)
Z51 is a badge some really goofy C6 owners will stick on their front fenders
Nobody mentioned the longer front air damn. The lower radiator hose is also different on Z51 models to clear the added frame bracing. Nobody that I know of makes a repro Z51 lower hose right now.
In fact, both of those were curved more than the hoses I've bought at parts stores, and both fit my 85 Z51, so actually there's 3 distinctly different hoses I've seen. That bracing became standard soon after anyways.
