Torque and HP curves for 88 L98 stock?
Old 05-07-2007, 05:44 PM
Carl Johansson
Carl Johansson's Avatar
Default Torque and HP curves for 88 L98 stock?
Anyone have horsepower and torque curves for a stock 88 with an Automatic trans. I need to do some gear calculations!
Carl Johansson
Old 05-07-2007, 11:06 PM
Aurora40
Aurora40's Avatar
I believe the owner's manual has one.
Old 05-07-2007, 11:11 PM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Calculations are for nerds. What are you trying to figure out. I have more calcs than einstein.
Trans wont affect it, the 4+3 was as inefficient as the auto, if not more so.
Old 05-08-2007, 11:28 PM
Carl Johansson
I am trying to calculate what rear end would be the most beneficial to us for Bonneville with an 88. So I need to know max HP rpm. from there I'm assuming i could look at theoretical speeds with the 2 different rear ends - then look at horsepower required to go that fast - then I would know if the car could pull the big gear. I could also figure out how much HP I will need to add if I can't pull the gear.
Carl I don't think I'm a nerd - but sometimes I play one on the internet!" Johansson
Old 05-08-2007, 11:32 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Go to my site, click on the label below the pic of my '88 and scroll down to the 1st Dyno Pull listed. You will see what mods had been done.
Since the intake was pretty much stock at that point the dyno shape should have been pretty much stock though power was higher.
Old 05-09-2007, 12:16 AM
Carl Johansson
The only dydno pull I could find was after mod IV - the HP maxed out at about 4600 rpm - but that was after a ram intake on mods II or III - so I'm not sure how that would have affected it!
Thanks,
Guys like you who keep impecable (where did the spell check go?) records sure help alot of us slovenly guys out!
Carl Johansson
Old 05-09-2007, 08:58 AM
mrc24x
mrc24x's Avatar
If you are just looking for a dyno run here is my completely stock '88 engine without a/c or air pump. Hooker long tubes through 3"duals/flowmaster 40's were the only add ons. It is a 4+3 w/ 3.07 rear. Kuhmo 315/35/17 V710's (25.4" Dia.)
Old 05-09-2007, 10:05 AM
Carl Johansson
Thats what I needed. looks like max HP is 4600 rpm, that is consistant with other things I have seen, so i will go with that number!
Carl
Old 05-09-2007, 10:37 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Stock 89. Catback, frisbee removed
Old 05-09-2007, 02:27 PM
vettet80
vettet80's Avatar
my vette is 88 with the 3.07 rear automatic but i dunno why it dynos much lower on hp. torque is higher than yours though.
dynojet best out of 3 runs i got 216 hp at 4200 and 338 tq 2800.
Old 05-09-2007, 05:59 PM
Wheelman
Wheelman's Avatar
Have you checked your timing? You can shift the hp/tq readings on the dyno around slightly by playing with your timing....Stock should be 6* BTDC
Old 05-09-2007, 06:04 PM
Slalom4me
Slalom4me's Avatar
with other things I have seen, so I will go with that number!
It wouldn't hurt to hedge and bump the peak HP 200-300 RPM back down
from 4,600 when running the numbers for a TPI intake configuration.
Old 05-09-2007, 06:36 PM
Carl Johansson
Yah - thats what i was thinking ken,
i will use 4400 and do the calculations - that may be a moot point if we go to HSR -
BTW - I do have an MSD6A ignition and HEI with the built in coil on top of the distributor
Carl
Old 05-09-2007, 06:40 PM
vettet80
vettet80's Avatar
my timing is exactly at 6. my motor knocks when its set higher than that.
Old 05-09-2007, 06:43 PM
LT4BUD
LT4BUD's Avatar
So what happened on your recent 142mph runs?????
What limited your speed??? What rpm and gear etc did you top out??
Tell us more..
Per Corvette Action Center, the 1988 was rated 245hp @ 4300 rpm
So if you peaked out at 4300rpm on your recent runs, you are there...
Old 05-09-2007, 07:16 PM
vettet80
vettet80's Avatar
Tell us more..
when i topped my car out at 149-150 mph the tach was 4300-4400 rpm so yeah i guess im up there at its max hp. makes perfect sense!
Old 05-09-2007, 07:38 PM
Carl Johansson
Tell us more..
More than likely just ran out of room. it was still pulling - but not hard! I can't tell you RPM - I was in a 25 mph crosswind - the streamliner that ran ahead of me got knocked over - a couple of roadsters flatspun - so i was more interested in horizons and finding the finish line - than in checking RPM.
The trans is a700R4 - and it was in 4th - i guess thats an 0.70 OD - if i remember correctly.
Next month we will have the video camera mounted in the car - looking at the dash - so we will know for sure - But I'm betting we didn't get to 4200 rpm in 4th.
carl Johansson
To Torque and HP curves for 88 L98 stock?
Old 05-09-2007, 07:48 PM
Carl Johansson
Default Here are the numbers!
assuming 4300 rpm
with a 28" tall rear tire
and a 4th gear ratio of 0.70 (700R4)
with a 3.08 rear end we would be clocking 166 mph.
If we drop it to a 2:59 rear end we will be going 197.5 mph
The trick is - it takes alot of HP to go fast = so even with the correct gearing - we are gunna need big ponies.
Using a frontal area of 19.8 ft sq
a CD of 0.3
to go 200 mph - i would need 340 HP just to overcome the wind resistance - and another 85 HP to drive the speed - so given enough time - if you gear it right you could make 200 with 425 hp rear wheel! (perfect dead on gearing ratios)
In comparison to go 150 mph - using the same inputs - only requires 145 HP to overcome the aerodrag and another 35 ponies to drive the speed - so to go 150 would require about 185 rear wheel HP
see I told you that wind resistance is the 800 lb gorrilla of landspeed racing!
Carl
Carl
Old 05-09-2007, 08:30 PM
mrc24x
mrc24x's Avatar
My guess is that I'm giving up a little tq with 1.75" headers and 3" exhaust but it seems to let it breath a little higher. Not too shabby for 194000 miles.
Old 05-09-2007, 08:36 PM
65Z01
65Z01's Avatar
OK here are some numbers from my '88 Owner's Manual:
RPM....CHP....Torque
800.......40......250
1,600...100......290.....HP/Tq cross point
2,400...145......320
3,200...215......340.....peak Tq
4,000...235......305
4,200...245......280.....peak HP
4,800...235......250
5,600...185......200.....both HP & Tq interpolated
These are the best numbers I can get from a plot that is 1 3/4" x 1 1/4"...
Quick Reply: Torque and HP curves for 88 L98 stock?
