Fuel gauge always reads full..
Old 05-24-2007, 06:51 PM
86GoldProject
86GoldProject's Avatar
Default Fuel gauge always reads full..
My fuel gauge always reads full, is there anything else it could be besides a bad sending unit? Also how do you replace the sending unit? Can you access it from the top?
Old 05-24-2007, 07:15 PM
MikeC4
MikeC4's Avatar
I would think that your '86 FP would be like the later LT1's and mounted below the filler neck. With any luck, you just have a stuck float level or bad level sender.
Old 05-24-2007, 08:30 PM
86GoldProject
a stuck float would be nice.. any idea where to get the gasket? I can't believe its actually that easy to get to.. wow lol
Old 05-24-2007, 08:34 PM
Johngunguy
Johngunguy's Avatar
Default lucky you!
I wish mine always read 'full'.
Old 05-24-2007, 08:47 PM
CFI-EFI
CFI-EFI's Avatar
Check your wiring between the gauge and the sending unit first. If you have to pull the sender, chances are you won't need a new gasket.
RACE ON!!!
Old 05-24-2007, 08:51 PM
86GoldProject
Which wire is for the fuel level sender? There are 3 wires on my module, a ground and 2 wires but I can't really tell what colors they started off as but one has a tracer...
Old 05-24-2007, 09:32 PM
jimmers
jimmers's Avatar
Old 05-24-2007, 10:12 PM
fsufan79
fsufan79's Avatar
You can get the fuel tank gasket at any chevy dealership it costs about $15 if i remember correctly. When i was having fuel gauge problems i took out my sending unit and then reconnected the wires and manually moved the float up and down to make sure my faul gauge would increase and decrease. Also something you can do while it is out you can take apart and clean the actual part that sends the signal as the float moves up and down. I have a document that is a detailed step by step on how to do this... pm me you email address if you want me to send it to you
Old 05-25-2007, 01:57 AM
Frizlefrak
Frizlefrak's Avatar
http://forums.corvetteforum.com/show....php?t=1574491
Old 05-25-2007, 10:30 AM
rws.1
rws.1's Avatar
You could try driving it more.....
seriously the posts above should help sort out the problem
Old 05-25-2007, 10:32 AM
billybonesmusic
billybonesmusic's Avatar
used to be a bad "ground"
Old 05-25-2007, 01:49 PM
mikey whipreck
mikey whipreck's Avatar
My gas gauge always read FULL until I cleaned the fuel level sending unit contacts. Now it works perfectly. Use the above tech tip
Old 05-25-2007, 02:42 PM
RRT vette
RRT vette's Avatar
I tried cleaning the contact on the sending unit on my 86 because the guage read full all the time. The ohm readings were not correct afterwards as posted in the tech tip. Put it all back in and the guage starting dropping as if it were reading correctly. I got to about 3/4 tank on the guage and I ran out of gas in the tank. Didn't work for me, but might for you.
Old 05-28-2007, 04:30 PM
86GoldProject
Followed the tech article and it worked. Now I need to find me a new gasket and strainer. Stores were closed today, and my gasket is FUBAR'd really bad.
To Fuel gauge always reads full..
Quick Reply: Fuel gauge always reads full..
