Throttle body bypass
If I don't hook the water lines to the throttle body on an '89 TPI engine, why do I have to connect them to each other? Can I plug them?
Can I cut them off? I'm using this engine in a hotrod, stock with ECU and all proper wiring. I would like to clean up the appearence of the engine as much as possible.
NCPunk: If I read your posting, you are wanting to remove the hose that connects the heater and throttle body to the cooling system. You can remove this "loop" without any problems assuming you modify the throttle body inlet and outlet point of the coolant system.
Here is a photo of how to bypass the throttle body (clean up) on a 89 Vette engine:
Do it
Do it
You can plug them if you wish but then your heater core isn't going to make a whole lot of heat. As there will be no coolant going through it.
I made a new line instead of adapting the hoses together. It looks much neater tucked away then crawling across your V/C. I also buzzed off the fittings on the TB so they didn't stick out looking fugly.
I bypassed my TB on a '93 LT1 using a blend of '93 and '95 hoses that looks beautifuly stock. No problems at all and she still pumps out great heat in the colder months. Just my 2 cents.
Perhaps I didn't state my situation clearly....I put an '89 Corvette 350 TPI into a '39 Buick. I rerouted the heater hoses directly from the engine to the heater as they would be in a '60's car. What I need to know is whether it matters if the throttle body outlets which are no longer being used, need to be capped and if not could I even cut them down for appearence and clearences?
Sorry for the confusion, thanks for all your interesting responses.
Sorry for the confusion...I think I'm going to cut them off and plug only the passenger side one.
Thanks for all your quick, helpfull responses.
