C4 Coupes vs C4 Convertibles - Chassis Flex
I have a coupe. I know lots of people that have coupes. One of the things that coupe owners talk about is the way our coupes feel when we take the targa top out - the descriptions range from mild symptoms of less than stellar chassis regidity to tales of feeling like the center of the frame was rotating about an axis (and it's right under you!).
My experience is about in the middle - when the top is removed, I can feel it in the steering column, as it picks up this very odd horizontal oscillation at low speeds, and just moves a lot when encountering rough pavement. The car also complains by generating more squeaks and rattles. Railroad crossings become a real adventure, as the car seemingly flexes through them rather than driving over them.
Here's what I want to know - do you convertible driver's contend with the same thing? Does your car flex and move around? Do you get significant cowl shake and movement of the steering column?
I know that convertibles got some additional bracings (primarily the cross brace under the car). However, there are coupe owners that have purchased not only the cross brace, but the camber brace, and the targa bar. These items usually help, but don't cure, the problem.
This is a concern of mine because a friend of mine is on a quest to obtain a convertible C4 or C5. I don't want to recommend a C4 vert if it's gonna feel like the automotive equivalent of the Straw Man.
I'd appreciate your feedback - both coupe owners that may have gotten their flexure under control, and convertible owners that can shed some light on the vehicle's characteristics compared to the targa-less coupe!
Thanks,
Steven
Thanks,
Steven
I have a 92 vert and I installed R&D racing camber brace and cross bar. These two items solved my "wobble problem" when stuck in uneven pavement and railroad crossings. But the nice thing is the more constant footprint the camber brace allows in auto crossing. Now let's be realistic, the C5 is better than our beloved C4 when it comes to stiffness and handling. It's just that the C4 looks better.
Probably about the same. After driving with the hardtop on the car doesn't feel as good with the roof off. However, before the winter installation of the top it seems to handle fine.
What I am trying to say is I'd bet that even with the top off of a coupe or an open vert (handle well, but they handle better buttoned up, since it only takes minutes for the change the driver notices the difference...) So I don't believe that either of them are ever wet noodles especially when compared to their contemporaries (other 80s and 90s cars.)
I know that when I am lifting my car even with the x-brace removed its stiff enough that I usually have all four corners off the ground when I'm installing the 3rd jackstand.
Mike
1 Post
Another small point. Somewhere around 94 they removed the heavy registration pins at the top of the doors & on the inside B pillar. That couldn't have helped anything besides the bottom line cost. My 92 coupe has them and feels stiff enough with or without the targa installed that I've never noticed any flex.
on my 91 vert if i would go up my drive way slow it would twist so much the interior light would come on .i tried taking off the x brace to see if it really helps it was the same crap .it was driving me crazy so i boxed the stock x brace and it was a heck of a lot better but still the light would come on if i went up a curb sideways but not as often as before .i ended up jacking the car up and you would not believe how loose some of the chassis bolts where and the k-frame bolts.i went from front to back and torqued all the nuts and bolt .it was like night and day the car felt stiffer no more light flashing .the biggest problem on my car was the front k-frame every bolt was loose and that's ties the 2 frame rails together my car only had 50k miles on it ,and has never been driven in the winter ,i never thought with that few miles on it ,it would have so many loose bolts.
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
My top has been off my '93 twice. I don't like the way it feels with the top off (shudders). My '85 rode the same with the top on or off. Weird.
Hmmm, Ive driven with my top off for months at a time in my 86. If my car has been "flexing" i guess im just an idiot and dont notice.
I don't think my car flexes much as far as i know, is it like the whole body flexes for you guys or what?
-bdahl
-bdahl
I notice a huge difference in flex with the targe off.
In 12 years, I have had the top out a few times. The first time I ever removed it I thought something was broken but the dealer said the vibration is normal since the car is considerably more flexible without the targa. To me, the vibration is most noticeable when you have the targa in for quite some time and then decide to take it out on a nice day. That first few minutes with it out is an adventure and you tend to really notice the vibration and oscillation. But after a few days I got used to it.
Doug
Doug
That's a hard one to say as the courses change every time you go. But I did move up the list of the fastest times. I was just about middle of the pack and then moved up several positions with the camber brace and cross bar. BUT, my experience and skills got better, too. The Vette seems to stick better with the add ons.
