Hard brake pedal solution, finally!!
Old 08-04-2007, 09:20 PM
  #41
Da Mail Man
Da Mail Man's Avatar
Originally Posted by Mike_88Z51
You may be correct. I don't have any training or experience working with the ABS modulator valve internals. My 88 FSM says that the Modulator valve consists of 3 solenoid valves, 2 accumulator chambers, and the return pump. There is one solenoid valve for each front wheel brake line circuit and one for the rear circuit pair. It is my understanding that the modulator valve lets fluid into the accumulator chambers in order to lessen the pressure in the brake line and reduce brake line pressure. In this way it can only LESSEN pressure and not increase it. (1988 FSM Page 5E-2) It might be possible that the ABS modulator valve in some way is able to restrict brake fluid to the rear brakes, but my understanding is that it does not do so by cutting off fluid directly. It just redirects fluid away via the solenoid valves which allow flow into the accumulator chambers, lessening pressure in the circuit overall. If the rear brake line solenoid valve or its relay is mal-functioning, it might be stuck open, allowing fluid into the accumulator chamber(s) and directly decreasing pressure from the master cylinder for the rear brakes. The same is also true for the fronts. This could be the cause of the 'Fred Flinstone Syndrome' some have reported. The FSM says the entire modulator valve assembly must be replaced as a unit if any part malfunctions.
The 88 FSM has a chart on page 5-3 outlining the possible causes for braking problems. There is no listing for "Fred Flinstone braking' but there are listings for 'Excessive Brake Pedal Effort'. The 2 primary causes listed are Leaking Vacuum System and Glazed Brake Lining. Also listed are: Restricted Brake Fluid Passage, Brake Pedal Linkage Interference or Binding, Restricted Air Passage in Power Head, Damaged Power Head.
......based on what i have been "chasing" around, there should be a fred flintstone brake section in the fsm!...if you read my previous post, i have done all that i can do w/out screwing around with the abs unit...pcolt had a similar problem and he actually changed out his abs (along with everything else that i have already replaced - part of being routine maintenence) and it did absolutely nothing...finally, he threw in the towel and changed over to the larger brake system....
Da Mail Man is offline
Old 08-05-2007, 01:32 PM
  #42
C4boy
C4boy's Avatar
Mike, thanks again for the reply. I realize you aren't trained in ABS, but you've been an excellent source of info! It's worth bouncing some ideas around. I'll keep doing some digging and if I ever change the module, I may tear the old one apart.
Sorry for the hijack, Fastmax!
C4boy is offline
Old 08-06-2007, 09:15 PM
  #43
fixit
fixit's Avatar
How can that be? OBD1 doesn't do jack for the ABS! OBDII does. '94 has OBD1 with OBDII connector, still is only OBD1.
fixit is offline
Old 08-09-2007, 01:19 PM
  #44
Mike_88Z51
Mike_88Z51's Avatar
Location: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
If swaping the ABS didn't improve things and changing to the larger brake system did improve things (with the ABS still intact), I'd say the cause was probably the smaller stock calipers and 12" rotors. I have always had excellent braking, but my Z51 came from the factory with the J55 big brake system.
Mike_88Z51 is offline
Old 08-09-2007, 01:47 PM
  #45
Da Mail Man
that is EXACTLY what happened..however, i can't see how the stock brakes could be as bad as they are (or at least mine and others) here on the forum and we are talking about the smaller brake system and not the larger...there appears to be something in the 12'' system that is a common denominator....
Old 08-09-2007, 02:05 PM
  #46
mseven
mseven's Avatar
If anyone is interested, according to the Killibrew code analyzer to test for stored codes in abs
90-91 cavity h, (but do need a tech 1 for codes 41,45,55,61,63)
92-93 cavity g, module 9. (also is asr /abs) clear using 9.7
mseven is offline
Old 08-09-2007, 11:32 PM
  #47
Travis93
Travis93's Avatar
Originally Posted by Travis93
What year shorts pin H and A? in 92 and 93 shouldent you short A and G to get into diagnostics?
For anyone that cares my brakes got real hard the same day this thread stared so I was very interested. I never did figure out what to jump to try and reset the ABS so I went ahead and replaced the power booster. Well my brakes are back to normal or maybe even better, it might be that I got use to not having the power but they seem much more powerful than ever before.
Travis93 is offline
Old 08-10-2007, 06:58 AM
  #48
Da Mail Man
.......the difference between yours and mine (88) is that my booster is fine and holding vacuum along with a few others.
Old 08-10-2007, 10:17 AM
  #49
engle1147
Support Corvetteforum!
engle1147's Avatar
My vacuum and booster are both good.....and the breaks still suck! I've never driven a C4 with toe touch brakes.
engle1147 is offline
Old 08-10-2007, 10:51 AM
  #50
tequilaboy
tequilaboy's Avatar
Hard pedal implies a flow restriction.
If the hard pedal and reduced braking performance was the only complaint, without any associated yaw or pull, this suggests that the restriction is affecting both brakes on one circuit equally. How can this happen?
On the front axle this is unlikely, unless the flow restriction is upstream of the ABS control valves. There shouldn't be a common flow restriction due to the ABS valves on the front axle since they are independently controlled.
On the rear axle, since this is a traction control unit, there should be a common valve that isolates the master cylinder from the ABS/TCS pump and possibly another valve which provides a flow path from the reservoir to the low pressure side of the pump, so that pressure can be built on the rear axle circuit during traction control without draining back into the master cylinder reservoir.
During diagnosis and repairs it is likely that the shop cycled the valves and activated the pump and in the process, built some pressure within the unit. This action may have been sufficient to clear what ever was causing the restriction due to either a stuck valve or contaminents in the brake fluid etc. Clearing the codes was likely irrelevant to correcting the problem.
I would suggest activating the ABS and or traction control regularly, otherwise you're not driving hard enough.
tequilaboy is online now
Old 08-11-2007, 02:05 PM
  #51
vette92_1
vette92_1's Avatar
Originally Posted by Fastmax32168
I know I am not the only guy that has complained of a hard brake pedal on a late model C4. My 94 brakes have always been terrible, In spite of upgrades over time of new rotors, quality pads, stainless lines, J55 upgrade, and a new M cylinder. The brakes still sucked. They always felt like they had no boost even though the unit checked out and worked normally. I finally broke down and decided to let someone else work on my car (I hate doing that you know) by taking it to Corvette Masters in Orlando.
With the ability to read the ABS unit it turned out that there were 3 codes stored in my computer. Even though the light came on when you started the car, the ABS went through the self check and then the light went off, ( in other words it acted as it should) the 3 codes that were in it were somehow preventing my brakes from working normally. They cleared the codes, went through the diagnostics on the unit to insure it was OK, and voila! I have brakes now.
I know I have seen lots of guys complain about this, and I would have never suspected the solution could have been so simple. So if your brake pedal requires way too much effort to stop the car and there seems to be no reasonable solution to it, I would strongly reccomend you have someone look into the ABS units subconscious mind and perform the necessary brain surgery.
Thank you Corvette Masters!
Roy
This all sounded great until I went out and checked mine for codes and there weren't any codes stored.
I agree with a lot of others the original breaks just seemed inadequate and they shouldn't be. Several years ago I replaced everything except the ABS unit. I eventually converted my fronts to the C5 Z06 rotors/calipers which helped tremendously but I don't think I should have had to do that in order to stop with confidence. Even with the C5 conversion I did, it stops a lot better than before but still in my opinion not as adequate as what I would expect it should be.
vette92_1 is offline
Old 08-11-2007, 02:37 PM
  #52
Da Mail Man
Quote;
***I AGREE!
Old 08-11-2007, 10:03 PM
  #53
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Wow, some good stuff inthis thread.
I have been battling the spongy brake syndrome. I was told to get some speed to it and nail the brakes (I already bled the daylights out of it ), couldnt get ABS to act, car stops like *** with all new stuff.
J55s should dtop and give change, the standard brakes on the ol 89 did very well, for stock I thought they were great .Bad brakes makes me hate the car.
Frustrating to say the least. Feels like air in the line but I cant find it .
I did have someone pumping the pedal while Iwas bleeding and they said they felt 0 improvement in the pedal while doing the rears, but an improvement up front.
Wonder if that valve is bypassing and pushing fluid to the fronts...
I am lost on how to troubleshoot this, Im terrible with anything more than old school brakes.
Help.
cv67 is offline
Old 08-11-2007, 10:16 PM
  #54
Da Mail Man
from the web..sorrry this will be long!;
Anytime the a brake system is opened to replace components such as calipers, wheel cylinders, the master cylinder, or brake lines or hoses, air gets inside. The air has to be removed by bleeding the brakes if you want a firm brake pedal. Air trapped in the lines, calipers or wheel cylinders will make the pedal feel soft and spongy. Air is compressible, so when the brakes are applied any air bubbles in the system must first be compressed before the hydraulic fluid will transmit pressure to apply the brakes.
As a rule, the brake circuits on most vehicles with anti-lock brakes can be bled in the usual manner — provided no air has gotten into the ABS modulator assembly. If the only components you replaced were downstream of the modulator (calipers, wheel cylinders, brake hoses or lines), chances are normal bleeding procedures will clear the lines of any unwanted air.
Brakes can be bled manually, with a power bleeder, injector tool or vacuum bleeder. It doesn’t make any difference which method you use as long as all the lines and components are flushed with enough fluid to remove any trapped air bubbles or air pockets.
The most common bleeding procedure is to bleed the brake furthest from the master cylinder first, then bleed the other brake that shares the same hydraulic circuit (which may be the other rear brake on a rear-wheel drive car or truck, or the opposite front brake on a front-wheel drive car or minivan). After these have been bled, you then bleed the other brake circuit starting with the furthest brake from the master cylinder.
Always refer to the vehicle manufacturer’s recommended bleeding sequence as this may vary from one application to another depending on how the system is configured. A good source for this information is ALLDATA or the OEM websites.
But what if you replaced the master cylinder, a brake line or valve ahead of the ABS modulator? Or, what if you had to replace the modulator or high pressure accumulator? Now you have a more difficult job ahead of you.
Air can be very difficult to remove from an ABS modulator assembly because of all the nooks and crannies inside the unit. The modulator may have eight to 10, or more, ABS/traction control solenoid valves, plus various check valves and dead-end ports. Some ABS modulators have special bleed screws to help you vent the trapped air when bleeding the system. Others do not and require the use of a scan tool to cycle the ABS solenoids while you bleed the system.
To better understand what may be required, let’s look at some bleeding procedures for some common General Motors ABS systems.
DELCO ABS-VI BLEEDING PROCEDURE
Introduced in 1991 as an option on Saturn, Buick Skylark, Oldsmobile Cutlass Calais and Pontiac Grand Am models, the Delco ABS-VI anti-lock brake system has been used on a wide range of General Motors front-wheel-drive vehicles, including Chevrolet Lumina and APV, Chevrolet Beretta, Corsica and Cavalier, Pontiac Grand Prix, Sunbird, Oldsmobile Cutlass Supreme and Buick Regal.
The Delco VI system is a nonintegral ABS system with a conventional master brake cylinder and power booster. It has four wheel-speed sensors, but is a three-channel system. The front brakes are controlled separately, but the rear brakes share a common ABS circuit. Attached to the master cylinder is the hydraulic modulator and motor pack assembly. The modulator is held by two banjo bolts at the master cylinder’s two upper outlet ports, and two transfer tubes at the two lower outlet ports. An important service point to note here is that the two lower transfer tubes and O-rings must be replaced if the master cylinder and modulator are disconnected from one another. This is necessary to prevent leaks that could cause the brakes to fail.
The modulator assembly has fluid chambers for all four brakes, two isolation solenoid valves, four check *****, a motor pack containing three bidirectional direct current motors with electromagnetic brakes (EMBs) and/or expansion spring brakes (ESBs), three ball screw assemblies, four pistons, a gear drive set and gear cover. The modulator motor pack, isolation solenoid valves, gear cover and individual gears are all serviceable parts and can be replaced separately.
The brakes on GM cars equipped with Delco ABS-VI may be bled using manual, vacuum or pressure bleeding. The usual bleeding sequence is right rear, left rear, right front, left front.
Before you begin, however, you must make sure the rear pistons in the Delco ABS-VI modulator are in the home position so the check ***** are unseated. If this is not done, you won’t be able to bleed the rear brake lines. There are two ways that this can be accomplished: With the Tech 1 or similar scan tool, select the F4 ABS Test mode, then select the F0 “manual control” option. You can now command the rear motor to drive the pistons to the home position.
Without a scan tool, open the front bleeder screw at the modulator. There are two, so be sure you open the front one. Then bleed the modulator. Close the screw, then bleed both front brakes starting with the right one first. After checking for a firm pedal, drive the vehicle above three miles per hour. The controller will automatically reset the system by commanding the rear motor to run to the home position. Once this has occurred, you can stop the vehicle and bleed the rear brakes.
DELPHI DBC-7 ABS
Introduced on 1999 Buick Regal and Century, and Chevrolet Tracker, the Delphi DBC-7 ABS Antilock Brake System is the successor to the earlier Delco ABS-VI system. It replaced ABS-VI in 2000 on Chevrolet Impala, Monte Carlo, Malibu, Cavalier and Venture, Pontiac Sunfire and Montana, and Oldsmobile Cutlass and Silhouette.
Unlike the earlier ABS-VI system, DBC-7 does not use motor driven plungers to cycle pressure in the brake lines. It uses solenoids like most other ABS systems. The Brake Pressure Modulator Valve has one inlet (apply) valve and one outlet (release) valve for each brake channel, plus two accumulators (one for each brake circuit). So the BPMV contains a total of six ABS valves for three channel system applications, eight ABS valves for four channel systems, or 10 ABS valves if the vehicle has TCS traction control. The inlet valves are normally open, and the outlet valves are normally closed. The solenoid for each valve is energized when the EBCM provides a ground to complete the circuit.
The GM passenger car applications are all four-channel ABS systems, so each of the four BPMV outlets is connected to the brake line for a separate wheel. The lines are color coded for identification:
• Left rear is purple;
• Right rear is yellow;
• Left front is red; and
• Right front is green.
DBC-7 BLEEDING PROCEDURES
Normal bleeding procedures can be used to bleed the individual brake lines provided no air has entered the ABS modulator. But if air has entered the modulator, the system will have to be bled using a pressure bleeder and scan tool:
1.Connect the pressure bleeder to the master cylinder reservoir.
2.Turn the ignition on.
3.With bleeder screws closed, pressurize the system to 35 psi.
4.Select the “Automatic Bleed Procedure” on the scan tool. The scan tool will then energize and cycle the ABS solenoids in the BPMV for one minute.
After this, the scan tool will instruct you to bleed each wheel. During this step, the pump runs and the respective release valve cycles for one minute. This is repeated for each wheel. Finally, the scan tool performs a final 20 second cycling of the ABS solenoids to purge any remaining air.
5.Relieve pressure at the bleed tool and remove it from the master cylinder. Then check pedal height and feel to make sure all the air has been removed and the pedal is firm.
BOSCH 5 ABS
In 1995, Corvettes were equipped with a Bosch 5 ABS system, which replaced the previous Bosch ABS/ASR system. The Bosch 5 system was also used on 1996 to 1999 Chevy Caprice and Impala, Buick, Estate Wagon and Roadmaster, and Cadillac Deville, Eldorado, Fleetwood and Seville. The modulator assembly uses solenoids for each brake circuit, but there are no special bleeder valves or special scan tool bleed procedure. So the brakes can be bled conventionally. The sequence if right rear, left rear, right front and left front.
OLDER INTEGRAL ABS SYSTEMS
Integral ABS systems were discontinued long ago, but you may still encounter this type of ABS system on some older vehicles. The GM applications include the Delco III Powermaster system on 1989-91 Buick Regal, Oldsmobile Cutlass and Pontiac Grand Prix and GTU models. It is functionally similar to the Teves Mark 2, Bosch III and Bendix 9 and Bendix 10 integral ABS systems used on older GM, Ford and Chrysler vehicles.
Integral ABS systems use a high pressure pump and accumulator for power assisted braking as well as anti-lock braking. As a rule, the accumulator must be depressurized before doing any type of brake repair work. Some of these systems can produce pressures of up to 2,700 psi, so never open a brake line or attempt to replace any of the ABS hydraulic components until the accumulator has been fully depressurized. This is done by pumping the brake pedal firmly 40 times with the ignition off.
After repairs have been made, the lines can be bled manually, with a conventional power bleeder, injector tool or vacuum bleeder. With all of these methods, leave the key off so the ABS pump does not pressurize the accumulator. Each of the brakes can then be bled in the usual manner following the sequence recommended by the vehicle manufacturer. On the GM cars, the usual sequence is right rear, left rear, right front and left front.
If the master cylinder or ABS modulator has been replaced, or there is air in either unit, the ABS modulator will have to be bled using a specific procedure. On the older GM applications with the Powermaster III ABS system, here’s the recommended procedure:
1.To bleed the isolation valves in the modulator, there are two bleeder screws. Start with the one toward the engine. Turn the ignition on and apply light pressure on the brake pedal. Open the bleeder screw and allow the fluid to flow until clear. Close the screw and do the same at the second bleeder screw.
2. Depressurize the accumulator by pumping the pedal 40 times with the key off. Wait about two minutes for the brake fluid to de-aerate, then refill the fluid reservoir with DOT 3 brake fluid.
3. Now you can bleed the boost section. This is done by applying moderate pressure on the brake pedal and turning the ignition on for three seconds, then off. Repeat this a total of 10 times. Make sure the pedal feels firm when you have finished, and give the car a road test to make sure the brakes are working properly.
Note: There is also a “solenoid bleed test” option you can use if you have a Tech 1 scan tool. This will cycle the hold and release solenoids to purge air from the booster.
DODGE TRUCK WITH KELSEY-HAYES 4WAL ABS
We’ll wrap up this story with one more example of what you might run into when bleeding ABS components. The following is for a Kelsey-Hayes 4WAL ABS system from a Dodge Technical Service Bulletin 05-03-94.
If the front ABS valve has not been replaced, the brakes can be bled manually with vacuum equipment or a pressure bleeder in the following sequence: master cylinder, rear anti-lock valve, combination valve, front anti-lock valve, left rear wheel, right rear wheel, right front wheel, and finally the left front wheel. Bleed only one valve or wheel brake unit at a time.
If the master cylinder is being replaced, bench bleed the master cylinder before installing it.
If the front ABS valve is being replaced, a special procedure is required:
1. Loosen bleed plug on new front valve about 1/4 to one full turn. Plug must be open to fully bleed upper and lower sections of front anti-lock valve.
2. Remove cap from bleed valve stem.
3. Install special Valve Depressor Tool 6670 on bleed valve stem. Slide notched side of tool onto boss that surrounds bleed valve stem. Stem must be held inward (in open position) to fully bleed upper section of new valve assembly.
4. Tighten thumbscrew on bleed tool 6670 just enough to push valve stem inward about 0.51-0.76 mm (0.020-0030 in.).
5. Apply brake pedal. Pedal will fall off significantly when bleed plug is properly open and bleed valve stem is correctly unseated (pressed inward) by tool.
6. Stroke brake pedal rapidly 5 to 10 times. This action will fill upper and lower sections of valve rapidly.
7. Bleed new valve assembly at each brake line fitting one at a time. Remember to close valve bleed plug before each brake pedal stroke. Continue bleeding until fluid flowing from fittings is clear and free of bubbles.
8. remove depressor tool from valve stem and install cap on stem. Then tighten bleed plug to 7-9 Nm 60-84 in.-lbs) torque.
Note: If the original front ABS valve assembly is still in place, bleed plug and bleed valve do not have to be open during bleeding operations. Just bleed the valve assembly at each brake line fitting one at a time.
A final note: Always check the factory service literature for any special procedures or tools that may be required when working on ABS brakes.
...Phew!
Old 08-11-2007, 10:25 PM
  #55
cv67
cv67's Avatar
St. Jude Donor '05
Ok, I think we are getting somewhere now. Good post Mailman
Central Coaster take note, I think this is our problem. Going to need your assistance on this one. Rears arent getting any umph to them. Your guess was right on.Sounds like Ive had air in the rears the whole time and havent figured out how to remove it.
Encouraging to say the least.
cv67 is offline
Old 08-12-2007, 12:36 AM
  #56
Da Mail Man
phew, i was going to edit and delete it because i though someone would blow a vein in their head because it was so long!
Old 08-12-2007, 08:35 AM
  #57
Da Mail Man
...(88).....i have a hard pedal (m/c and booster checks fine) and still have fred flintstone brakes...ugh!....i am still waiting to hear the results of someone who used the "arm jesture on brake handle" method as previously mentioned......
To Hard brake pedal solution, finally!!
Old 08-12-2007, 10:02 AM
  #58
Fastmax32168
Fastmax32168's Avatar
And you may be correct about that. But regardless of whether or not it had to do with the codes or the cycling of the unit using a tech 2 my point was the same. Which is: As a die hard do it yourselfer who has not taken any of his cars to anyone to fix in years and years, this may be an instance where it is worth it to take to someone with the proper equipment to service it, rather than making yourself crazy and pissed off at your car trying to save $100.
BTW my brakes continue to work great, If you are the passenger you better be strapped in when I nail them now.
Roy
Fastmax32168 is offline
Old 08-12-2007, 11:58 AM
  #59
Da Mail Man
Roy
....whom is this addressed to??..if it is i then, i have no flow restrriction and the amount of fluid that comes out of the bleeders is significant...
Old 08-12-2007, 01:26 PM
  #60
C4boy
C4boy's Avatar
I agree. While fixing my ABS system hasn't been a high priority, I was ready to have the dealer test the system. I ended up buying the Kent-Moore tester instead because the service mgr. didn't know his *** from his elbow and couldn't give me a straight answer.
C4boy is offline
Quick Reply: Hard brake pedal solution, finally!!
