84 rear end gear ratio codes
Have a 84 rear end I took out of a corvette many years ago. Was wondering if anyone can post the rear end codes for this year. I want to use it but need to determine the ratio to get the computer set up correctly. Thanks. I will have to go to the shop to get my numbers. Thanks
The RPO code #HE3 was in the 51,137 that came with the standard 3.07:1 diff. The other 410 had both RPO codes G92, performance ratio and GW4, for the 3.31:1 ratio. There are numbers stamped on the bottom of the carrier that either are, or will decode, the ratio.
RACE ON!!!
RACE ON!!!
