Golen 383 - 4 bolt splayed caps, forged SRP Pistons and cylinder surface
I bought an LT1 block from them and splade mains no problem here.
You should get atleast $150.00 back for the non coated pistons and $400.00 back for the lack of the splade mains .I would rather have the 4 bolt anyway.I would have had the 4 bolt caps splade installed on all the journals if you are going to run a pro charger.You will sure be shocked when you go to buy that rear one piece main seal for the crank.I also know that unless they used the tool to set up the crank for the seal you will have one bad rear seal oil leak.The block off you should be able to purchase at any auto parts store.Don't for get the gasket
Received 3,043 Likes
St. Jude Donor '05
I personally feel billet caps/iron block=long term use Best for track use only..
Iron caps/block
Expand and contract at the same rate.
my .02, although Im not a machinist.
Dont worry about strength, studded 4 bolt is plenty stout plus you appear to have good bottom end parts
Iron caps/block
How do I know what the correct seal is?
I'd like to buy from Summit but there are 3 different seals ...
1. FPP-2919
Fel-Pro Performance Rear Main Bearing Seals
Rear Main Seal, 1-Piece, Silicone, Chevy, Small Block V8/ V6, Each
2. FEL-BS40520
Fel-Pro Rear Main Seals
Rear Main Seal, 1-Piece, Rubber, Chevy, Small Block, Each
3. FEL-BS40626
Rear Main Seal, 1-Piece, Rubber, GM/ Excalibur, Each
Golen is a worldclass shop!
Iron caps/block
Iron caps/block
St. Jude Donor '05
Lots of higher volume shops will take whatever blocks they can get from their core suppliers and machine/change them to get a motor out the door. Some is due to availability, there are blocks that are getting hard to come by period, some that are already bored over too far, etc.
I want to hear what Golen will do for you , this is the first negative Ive heard of them. Hope to hear something positive.
By the way, do you guys with Golen engines got them blueprinted?
I got only the "Fuel Injected Chevy Setup Guide" and no information about any clearances or weights.
Here are a couple of people over at thrdgen.org with recent problems with Golen Engine Service.
http://www.thirdgen.org/techboard/af...e-no-good.html
Engine ID
Engine block # 14093638, 89-93, OHV, RWD, TBI, roller lifters, center bolt valve covers, high swirl intake ports, right hand dipstick. This block also came with single piece rear seal.
Eike,
Speak with Golen they have a reputation to maintain. If they don't reimburse you or cover the shipping and provide you with what you want I will never reccomend them and the money they would have lost from covering shipping to you will be multiplied by those customers they lose.
I for one was considering purchasing a 2 bolt block and was considering having them machine everything for me. After this, I definitely will not be getting it done as I'm in canada and the last thing I need is to have something 200 lbs shipped to me and be wrong.
Golen has a good rep and I hope they step up to the plate and cover all shipping back to them and ship you the right block at their expense. I would expect NO less than that from them.
Canada ... you are lucky. I live in Germany
Thanks for the link, Hooked on Vettes. It seems that I have to check everything.
I paid $6,077. Golen did not reply my e-mail until now.
#35
You have a one piece rear main seal.Not just the seal the whole part.
That is the retainer that holds the seal for the crank,the seal and the gasket.I would not bat an eye if it was $300.00 that is what my 2 piece cost
I don't think you were very clear about what you new you wanted.I would have faxed the info so their were no ??????? about what you wanted.6k sounds about right.I would have gone with a complete motor if it was me.The motor they did for me was an LT1 which is hard to find .Yours is just a regular gen 1 block.
#36
I can buy a used retainer/housing off ebay for a few dollars so that is not a problem.
Complete motor ... I wanted the new AFR heads with Swain Techs TBC coating so that was not an option at the time I ordered.
Btw, my mech also says that the studs are not correct installed.
So I'll check everything what I can check by myself. Currently I can't really trust this engine.
#38
I just checked with my mech ... he recommend screw the studs out so that the nuts are fully threaded and torque them down to 65 foot pounds. The rust may not be a big problem.
Golen did not answer my first e-mail till now. I'll wait another day till I send a link to this thread.
#39
#40
I would carefully read Golen's warranty to determine how to place a claim. Pay particular attention to the "Claim Procedure" section, paragraph 7, which states "Disassembly of the engine by any parties other then GES will void the warranty unless it is specifically authorized by GES." I assume that this warranty is the same as the one listed below which I obtained from their website.
LIMITED THREE YEAR LABOR WARRANTY
Golen Engine Service (hereinafter referred to as "GES") warrants that their high performance engine shall be free of defects from workmanship, when installed properly by a competent technician used for normal street operation and serviced at proper intervals for a term of three years from the date of the purchase.
GES will provide full labor repairs and replacement of all parts needed to repair your engine in the event of a problem upon start up. Inspection of the engine must be completed by GES to assure that the engine was not run longer than a few hours. If GES finds that the engine was run longer than a few hours the original Limited Three Year Labor Warranty will not apply.
GES (under the Three Year Labor Warranty) will provide all repair, labor, inspection, machining and assembly at no cost to the original purchaser. The purchaser will be responsible for the cost of all parts needed to repair the engine under the Lifetime Labor Warranty. This warranty only covers the engine itself, at no time does this warranty or any other warranty given by GES cover the labor costs to remove or replace the engine from a vehicle or does it pay the labor costs of any mechanic. No exceptions.
EXCLUSIONS and LIMITATIONS:
This warranty does NOT cover damage or loss due to the following:
1. Misuse, maintenance neglect, abuse, vandalism, abnormal operation or accidents, not changing oil on time or not enough oil.
2. Defective or improper installation, Distributor not installed properly in turn melting pistons and rings or destroying bearings.
3. Improper break in: Camshaft wearing too soon, in turn ruining camshaft.
4. Environmental conditions, overheating, or freeze cracks: warped heads or cracks in head or block.
5. Over revving: bent or broken connecting rods, bent or broken push rods
6. Foreign material in combustion chamber or oil pan, bolts or nuts dropped into cylinder destroying pistons and valves.
7. Failure of components or parts not furnished or otherwise approved by GES for installation, or components or parts unsuitable for use with engine.
8. Damage to pistons and other components from detonation or preignition: distributor not installed properly, too much timing, bad fuel and not enough octane.
9. Crankshaft thrust surface worn: defective or improperly installed clutch, torque converter.
10. Internal modifications- any internal modifications will result in a warranty void.
11. Nitrous Oxide or Supercharger- installing these components on an engine that isn't properly set up for them will result in a void in warranty. Consult the GES Tech line if unsure.
12. Overfueling or other dilution lubrication: carb is too big or is out of adjustment.
THIS WARRANTY DOES NOT COVER OR PROVIDE PAYMENT OR REIMBURSEMENT FOR THE FOLLOWING SERVICES:
1. Replacement of oil, anti freeze, or any other substance
2. Towing charges, vehicle rental, or other substitute transportation
3. Diagnostic time, labor to remove and/or reinstall engine, or service calls
4. Parts or items associated with warranted engine
5. Transportation or lodging
6. Loss of time, income, sales or profits, loss of use of vehicle
7. Lift, dock, or storage fees
8. Tune-ups or replacement of belts, hoses or maintenance items, routine
regularly required maintenance
9. Injury or death to persons or damage or destruction of property; consequential or incidental damages
10. Shipping warranted engine to and from GES
CLAIM PROCEDURE:
Immediately after the discovery of a potential defect the customer must comply with the following procedure:
1. Discontinue the use of the engine
2. Do not pull engine out of vehicle
3. Contact the sales person at GES that you originally purchased the engine from
4. Let GES help you figure out what is wrong with the engine (95% of the problems can be fixed with the help of the GES tech while the engine is still in the vehicle).
5. Unless a field repair is specifically authorized by GES, the engine or part thought to be defective must be returned to GES for evaluation. A copy of the customer's original invoice or receipt must accompany all returned engines or parts.
6. Returned engines must be returned with all parts intact that were originally furnished with the engine or charges will be made for the missing parts.
7. Disassembly of the engine by any parties other then GES will void the warranty unless it is specifically authorized by GES.
BY PURCHASING THIS ENGINE FROM GOLEN ENGINE SERVICES IT IS UNDERSTOOD THAT THE CUSTOMER ACCEPTS AND AGREES TO COMPLY WITH THE TERMS OF THE WARRANTY.
A SIGNED COPY OF THIS WARRANTY MUST BE RETURNED WITHIN TEN DAYS OF RECEIVING THE ENGINE. FAILURE TO DO SO WILL VOID ANY AND ALL WARRANTIES.
BINDING ARBITRATION
PLEASE READ THE FOLLOWING CAREFULLY, IT CONTAINS VERY IMPORTANT INFORMATION ABOUT YOUR RIGHTS AND OBLIGATIONS AS WELL AS LIMITATIONS AND EXCLUSIONS THAT MAY APPLY TO YOU. THIS DOCUMENT CONTAINS A DISPUTE RESOLUTION CLAUSE.
Any claim against Golen Engine Service (hereinafter referred to as 'GES') its agents, employees, successors, assigns, or affiliates arising from or relating to the purchase of parts or an engine this or this agreement, or it's interpretation or the breach, termination or validity thereof, the relationships which result from this agreement (including, to the full extent permitted by applicable law, relationships with third parties who are not signatories to this agreement), GES's advertising or any related purchase SHALL BE RESOLVED EXCLUSIVELY AND FINALLY BY BINDING ARBITRATION ADMINISTERED BY A STATE OR NATIONALLY RECOGNIZED ARBITRATION FIRM. The arbitration will be limited solely to the dispute or controversy between customer and GES. These terms and conditions apply (1) unless the customer has signed a separate purchase and sale agreement with GES, in which case the separate agreement shall govern, or
(2) unless other standard GES terms apply to this transaction.
FORUM SELECTION CLAUSE:
It is agreed to by and between customer and GES that all disputes and matters whatsoever arising under, in connection with or without incident to this contract, warranty SHALL BE ARBITRATED EXCLUSIVELY IN AND BEFORE A COURT LOCATED IN THE STATE OF NEW HAMPSHIRE, TO THE EXCLUSION OF THE COURTS OF ANY OTHER STATE, TERRITORY, OR COUNTRY. This is enforceable on all contracts regardless to where product has been shipped. Customer hereby waives any venue or other objection that he may have to any such action or proceeding being brought in any court located in the State of New Hampshire. If either party is to institute or commence litigation in any venue or format other than that specified above, specifically binding arbitration in New Hampshire it shall be liable to the other for all costs, expenses, and attorney fees associated with that action.
Please sign and date here: _____________________________
(Full Name here)
CLAIM PROCEDURE:
BINDING ARBITRATION
(Full Name here)
