On a 93 Vette, how do I know if knock (or false knock sensing) is slowing me>
People have brought up some good points..
I have a 93 Vette 6speed. How would I know if I am getting knock , (or retarded timing due to false knock sensing) that would be slowing me down?
I am under the understanding that I can't put in an LT4 knock sensor on my car, that it will only work for later model Vettes.
I do have a custom Ed Wright chip, LT4 hot cam kit installed, ported heads, and a K&N air filter, new opti and fuel filter
Is there an easy way to test this?
-Dave
-Dave
Re: On a 93 Vette, how do I know if knock (or false knock sensing) is slowing me> (dizwiz24)
The knock sensor sends info to the ESC,thats the little flat square box you see on the side of the underhood compartment.You can disconnect it & see if it runs better.I think thats the part you want from an Lt4.
Disconnecting the sensor will make it always run retarted but not the ESC.
