Parking Brake Lever
Parking Brake Lever
Does anybody know if a Parking Brake lever for a '89-'96 will fit an '86? I know according to my microfiche there were 3 different models. '84-'87, '88, and '89-'96. The '84-'87 has been discontinued. They must be different, but will it work without modification? This is the inside part you pull to put on the brake.
Barrier:confused:
Barrier:confused:
Re: Parking Brake Lever (Barrier)
dont know if it will work but new it is a $60 part fm the last detail. not worth buying a moving part used at this price I changed it out on my 89 and feels like a new car somewhat.
Thanks for the reponse. This is a NOS purchase on e-bay. Guy said '84-'92, yet when I checked turns out 3 different models.I am just trying to figure out if it will fit and work without changing everything in site.
thanks in advance for help.
Barrier
Barrier
I asked '18carfan' (our resident source for GM parts at wholesale) about this. He too has an early C4 that he tried to find a parking brake solution to. He assured me the later C4 parking brakes (88+) will NOT fit.
I watched eBay for months(years?) for an '84-87 parking brake handle assembly in near new shape. Never saw one.
So I finally tried to redo mine. I'm surprised how well it came out. Check my web site below - the link about the new interior going in. Black shoe polish fixed the leather up to new-looking. But the rubber handle came out good too. It had been scratched and dinged. I took wet/dry sandpaper (250, then 400) and dry sanded each side. I took just enough off to get rid of all the dings and scratches. Then I took a Dremel tool with a cotton buffing tip. Nothing on the tip, just dry cotton. Medium speed, I buffed all sides of the rubber handle. That smoothed out the fine scratches left over from the 400 sandpaper. Then I worked black shoe polish into it, and polished it, to turn it dark black again. I then cleaned up the plastic button on the end, and it looked virtually new.
I didn't have much play in the mechanism. Actually, I did - some previous mechanic didn't put the 'C' clip back on the center pivot bolt. Once I put a new one one, and lithium-greased the mechanism, it was pretty solid. Certainly not an example of precision German mechanical engineering, but it was fine. My car has 105k miles on it, so the parking brake's been used a few times.
Is there slack in the brake cable that may be allowing parts to thrash around?
Re: Parking Brake Lever (gh86E)
Re: Parking Brake Lever (LWesthaver)
In my 1987 the lever is leather wrapped (or I should say WAS leather wrapped). The car has 107k miles so it's seen some use. ;) Actually, it's pretty nasty looking at the moment. I've been wondering if someone sells a little leather sheath that I can just resew onto the handle. The old one is totally worn and ripped and beyond repair. :eek: If not I suppose one of these eons I'll take the old one off and use it for a pattern and just find a piece of leather at a fabric shop or upholstery shop. ~Juliet
Greg, I've got an 85 and my parking brake lever is completely wrapped in leather. I thought they all were like that. Do you know when GM started using rubber handles on the brake lever?
My rubber handle looked like rubber initially, but I'm not so sure now. When I was cleaning it up, I noticed on the ends that there were 'foldovers', like it's a covering that was foldered-over at the ends (like wrapping a present). It looked like rubber, stuff sanded off like rubber. But the handle had sharp edges and foldovers.
But if you've got leather right up to the pushbutton, then just take it to an auto interior shop - should be a few of them in any major city.
My '87 is totally wrapped in leather - well sorta. It's kinda falling off on the wide handle part. :eek: It has one sewing seam down the top. The only non wrapped part is the little push button. The narrower diameter shaft part is also leather wrapped. Thanks for the idea of taking it to an upholstery shop.... Hadn't thought of that. :) ~Juliet
