285's will fit in the front without rubbing right?
Old 11-08-2007, 02:22 PM
vettin_it
vettin_it's Avatar
Default 285's will fit in the front without rubbing right?
I just purchased some Z06 rims from Bob at House of wheels and planned on putting my current rear tires(285/40/17) on the new front rims.
I was calling on prices for new rear tires(wider ) and blah blah blah the tire guy wanted to sell me 4 tires because he insited the 285's will not work on the front.
So he is wrong... right?
Old 11-08-2007, 02:55 PM
Rimcrew
Rimcrew's Avatar
Folks on this forum are running 315's on the front, so it shouldn't be a problem to slide 285's in there. Maybe someone who has actually done it can chime in. I'm just reporting what others have said.
Old 11-08-2007, 03:26 PM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
I run 295/35-17s on the front of my 86. Its lowered an inch and no rubbing problems
Paul
Old 11-08-2007, 04:16 PM
JEFNLSA
JEFNLSA's Avatar
I have 285's up front and my car is lowered and still no rubbing at all...you'll be fine.
Old 11-08-2007, 05:06 PM
VMAX451
VMAX451's Avatar
285's all around on my '92, no problems whatsoever.
Old 11-08-2007, 06:07 PM
aminnich
aminnich's Avatar
[QUOTE=JEFNLSA;1562664434]I have 285's up front and my car is lowered and still no rubbing at all...you'll be fine.
Same here! 285s up front pushed around by 315s.
Old 11-08-2007, 06:31 PM
wingman4rent
wingman4rent's Avatar
What size rims are you guys all running I have 17X10s so I think they should be perfect for 285/40/17. I was thinking 295/35/17 but I have not seen many companies that make them, what size rims would you need for those?
Old 11-08-2007, 07:50 PM
aminnich
aminnich's Avatar
285/40s on 9.5 and 315/35s on 11". Your 10" should be fine for the 285/40s, but I would not go any smaller tire on them.
Old 11-08-2007, 08:29 PM
0Paul Ruggeri
Former Vendor
The tires are Hoosiers I use on the track. They're on facory sawblades, 17x9.5?
Paul
Old 11-09-2007, 12:44 AM
vettin_it
vettin_it's Avatar
Thanks for all your input guys! I was pretty sure but wanted to check and be certain. I will post pics once I got the wheels and tires on!
To 285's will fit in the front without rubbing right?
Quick Reply: 285's will fit in the front without rubbing right?
