a few questions zz9 cam vs lt4 cam
i am a bit confused, the corvette i am buying is a 96 lt4 with zz9 cam installed, all of the specs i see at quoted with a 1.5 rocker, i thought the 96 lt4 came with crane made 1.6 rockers for gm. what would the lift work out to be with a 1.6 ratio ?
Duration @.050 is 212/226 .483/.520 112 LSA this is the zz9 spec
what is the difference in lift when you use a 1.60 ratio is it just adding .1 to 483= 493 and 520+ .1= 530??
how is this different from a Hot cam with a 1.60 ratio
thanks in advance
thanks in advance
You divide the lift by 1.5 to get the Lobe lift number. Multiply that number by 1.6, 1.65, 1.7 or what ever ratio rocker. .483 = .322 x 1.6 = .515 lift. .520 = .3466 x 1.6 = .555 lift. I just add .035 to whatever the lift is, when I don't need the exact numbers. I personally add 2* duration when going from 1.5 to 1.6 too. So you're looking at 214/228 & .515/.555 lift. Performance should be very similar to a Hot Cam.
