L98 383???? Need Rebuild Ideas
I am in the process of rebuilding an 89 L98. I am considering stroking it but I do not want to change anything with the intake or injection. I want to keep everything as stock as possible on the outside and do not want a bunch of tuning issues. Maybe I should just bore it and put a cam in it? Any ideas would be helpful. My plans are to leave the stock exhaust manifolds on it also. Bottom line---I want it to look factory stock but want some more beans for the motor. Preferably torque as it will be a driver.
All engines are air pumps, the more air in, the more air out= more power. You must increase the air in and out to increase power. I would get a hi flow TPI intake manifold, some bigger runners, and have the plenum ported. Maybe have the heads ported, and go w/ a hot cam.
If you are not going to use a Mini Ram or Super Ram, I would not stroke the engine.
Good luck, let us know how it turns out.
Randy
BTW, learn to use the search function, lot's of good info here.
Randy
Without a lot of explaining:why do you want to add capability when you don't use all you currently have? As a driver your 89, in decent condition, will have more than enough power to do anything you want or need to do.
Location: One day you're a Comet...the next day you're dust... Arkansas
