Replacing 700R4 Shift Linkage Seal...any advice?
Old 01-10-2008, 10:06 AM
JXAce
JXAce's Avatar
Default Replacing 700R4 Shift Linkage Seal...any advice?
I’ve narrowed the source of my transmission leak to the shift linkage seal on the driver side of the transmission (there are drips forming on the linkage itself, as well as fluid running down to the front driver’s corner of the pan).
Can this seal be replaced with the transmission in place? Do I need to drop the pan? Remove the Y-Pipe? Get a special tool?
Old 01-10-2008, 10:20 AM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
I don't remember dropping my exhaust when I replaced mine but I may have. The hard part is getting the old seal out obviously. I used a small flat blade screwdriver to get in there and work it out. Once out, just tap the new one back in with a socket the same outside diameter as the seal. You can use a long screwdriver placed between the tunnel and the socket as a pry bar to press the new seal back in. Don't forget to coat it with ATF before installing.
Old 01-10-2008, 01:24 PM
Greg Gore
Greg Gore's Avatar
There is an inexpensive tool available to pull these seals out in the car. Some of the A4 experts may chime in here later with the tool brand and model number.
Old 01-10-2008, 10:07 PM
JXAce
JXAce's Avatar
I've purchased the replacement seal from Autozone and I will attempt to install it tomorrow evening...I'll post back and update how it goes...
Old 01-13-2008, 10:50 AM
JXAce
JXAce's Avatar
I can't get leverage to get the old seal out with the shift shaft in the way. Is it possible to easily remove the shaft by dropping the pan? Or is the valve body and transmission internals going to pose a problem?
Old 01-13-2008, 10:54 AM
Greg Gore
Greg Gore's Avatar
You need the tool I mentioned. The job is easy with the tool.
Old 01-13-2008, 11:11 AM
JXAce
JXAce's Avatar
Anyone know where I can buy this tool? Model#?? Website??
Old 01-13-2008, 11:14 AM
Pete K
Pete K's Avatar
KD makes one. I do not know the part number, but there have been many posts about it in the past. Try the advavce search feature, or check KD's website. I am positive KD makes one.
Old 01-13-2008, 11:17 AM
94z07fx3
94z07fx3's Avatar
Is this the tool you're talking about? (clicky)
Old 01-13-2008, 11:20 AM
Pete K
Pete K's Avatar
Although that looks handy, I am referring to a specic gm park shaft seal puller and installer for GM cars.
Old 01-13-2008, 11:36 AM
JXAce
JXAce's Avatar
I found it: Click
It is made by KD Tools and its model number is KDT2393. I just ordered it and it should be here next week. Looks like a breeze to use. Hopefully there won't be a clearance issue with the tunnel and the exhaust.
Old 01-13-2008, 12:01 PM
Greg Gore
Greg Gore's Avatar
That's the one, no clearance issues. You will be glad you ordered it! Use the black GM pan gasket torqued to 90 lb/in I think it is. Be sure to check the dipstick tube grommet too.
Old 01-13-2008, 01:16 PM
steven mack
steven mack's Avatar
I have removed them by poking a small hole in the metal part of the seal the inserting a small screw and pulling the seal out with pliers . This was out of the car I dont know how hard it is to reach in the car.
Old 01-13-2008, 02:20 PM
Vette Gator
Vette Gator's Avatar
I bought the shaft seal pull tool for my TH350 that looks just like the one in the picture. Does the same tool work for the 700R4?
Old 01-13-2008, 06:21 PM
comp
comp's Avatar
Old 04-26-2017, 01:43 PM
BWD111
BWD111's Avatar
Default How tight if a fit is it when using the puller tool
I have ordered the tool and have the lifts and stuff needed but wondering how tight is the fix going to be when using the puller? 1985
Old 04-27-2017, 03:17 PM
BWD111
BWD111's Avatar
Default Great video
Sorry he doesn't like the 84. Now he does speak of the seal In the video and that is why I posted it here.
Gotta love the 85
https://youtu.be/lTMSEMMED3Q
To Replacing 700R4 Shift Linkage Seal...any advice?
Old 04-28-2017, 11:16 AM
Silver85
Silver85's Avatar
Its pretty easy especially if you have a lift. I did mine on jack stands and didn't have a problem.
Old 04-28-2017, 04:16 PM
confab
confab's Avatar
No, it's not a problem. You can pull the pan and remove a clip and a 15mm nut from the linkage, and pull the rod out.
(It helps if you grind it a little where the rooster comb contacts the rod, inside the pan, before removal. It tends to "smoosh" out there a little.)
Old 04-29-2017, 03:26 PM
BWD111
BWD111's Avatar
I received the tool but it stops on the notched part of the screw and even after hitting with a hammer the tool won't go past the notch to come in contact with seal. Luckily napa has the tool which I'm going to bring the tool I have to make sure it's not the same. If it is I will use a step but to increase the size of the opening on the tool. But yes seal is easy to get to but hard to hit with a hammer due to exhaust is in the way.
Quick Reply: Replacing 700R4 Shift Linkage Seal...any advice?
