96 LT4 Clutch install cost
Corvette Enthusiast
How much is the average price for a clutch install on a 96 lt4? I just got a quote for $2300 from a place called Corvette specialty. I think that is a bit much....whaddya guys think?
James
James
While that sounds really high at first, you can't turn a C4 flywheel due to the tight tolerances (clutch might not fully engage). A new dual mass flywheel is $700, so that could be a significant part of the cost.
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I've only had to replace 1 clutch but here goes. I did not replace my flywheel. I used a die grinder with a green stuff buffer disc and cleaned it up. Something akin to putting a new crosshatch on it in a way. Then replaced just the clutch/PP/throw out bearing. The thing worked great for the next 50k miles till I sold the car. I beat on that thing and it never gave me any issues. My total cost was under $500. (free labor, me)
The resurfacing is only one part of why you usually replace the DM flywheel. My brother had a DM flywheel in a car break a spring (at only like 60k miles) and severely imbalance the motor. I'd personally hate to pull the tranny and do a clutch, only to have the flywheel crap out on my later. I'm not a big fan of the DM, and if I owned a ZF car I would go the single-mass route and just live with the chatter. All up to you, though. If you did your own work I'd say not replace the flywheel, just scuff it a little (assuming it's not badly blued or something). If I was paying someone for the labor, I'd replace everything in one fell swoop to avoid a second round of labor charges.
