Turn a LT1 into a 383?
Old 01-18-2008, 06:32 PM
bobmic93
bobmic93's Avatar
Default Turn a LT1 into a 383?
Whats all involved ? Does the motor have to be pulled to do this or can a assembly kit go in without pulling the motor? I see rods , pistons, rings and cranckshaft for around 2 grand. Sound right? Whats the difference between 383 and a stroker 383? Is a 396 considered a stroker? How much does this project cost for a pro to do at $90 hr shop rate? Where you satisfied with the performance results? Whats difference between long and short block? Thinking of next years project and can always count on you guys for info. Thanks!
Old 01-18-2008, 06:51 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Shortblock-Block with crank, rods, pistons, cam (usually),oil pump etc installed.
Longblock-Same except add cyl heads, intake.
You can get a good rotating assy for $15-1600 or so.
383 is a stroker. 4.030 bore, (standard bored .030 over), 3.75 stroke up from stock 3.48). 396 uses slightly longer stroke. Possibilities are endless as far as brands, prices, etc. Highly recommend stroking, youll never go back to a 350 again after having had one.
Old 01-18-2008, 07:01 PM
Kevin Woods
Kevin Woods's Avatar
Originally Posted by bobmic93
.....Does the motor have to be pulled to do this.....
Yes.
.....I see rods , pistons, rings and cranckshaft for around 2 grand. Sound right.....
Yes.
......Whats the difference between 383 and a stroker 383?......
Same thing. Term stroker comes from the 383 having a crankshaft with a longer stroke than stock.
.....Is a 396 considered a stroker.....
Yes. A 396 has more stroke than a 383.
396 = 3.875" Stroke
383 = 3.75" Stroke
350 = 3.48" Stroke
......How much does this project cost for a pro to do at $90 hr shop rate......
Picture a cost of the stroker kit, plus the labor to bore the 4" cylinders to 4.030", plus the cost of a rebuild. Also, some stroker kits will require some clearancing of the block to allow the rod ends to rotate without contacting the block.
Total cost of just the engine itself can cost $3000 to $6000 depending on parts used and associated labor costs. Heads will be extra .
....Whats difference between long and short block....
Short Block = assemble engine block w/just rods, pistons, bearings and maybe cam.
Long Block = short block + Heads + Oil Pump/Pan + cam. In some cases, timing unit and maybe even a water pump will be part of the deal.
KW
Old 01-18-2008, 07:02 PM
94z07fx3
94z07fx3's Avatar
Stock vs Stroke (clicky)
Old 01-18-2008, 08:17 PM
bobmic93
bobmic93's Avatar
Is it wiser to just buy a new rebuilt fully assembled stroker motor and maybe sell my LT1 block? Though it would be hard for me to depart with my beast. Shes been good to me. 60,000 miles
Old 01-18-2008, 10:15 PM
HFDFyrefytr
HFDFyrefytr's Avatar
Sweet! So stroking the engine gives you a taller deck height!!!
lol...just noticed that the pics are staggered....I take it back....not very funny when you are WRONG!
Old 01-18-2008, 11:14 PM
staugur
staugur's Avatar
If there's nothing wrong with your engine and there shouldn't be at 60k and you just want some more ooomph why not just put a blower on there.$2500-$3500 and you don't need to pull anything out. If you want big gains in HP just stroking your motor isn't going to do a thing.On top of the cost of boring it,fitting new pistons and rods,crank,machining the block you will need to change the cam,flow the heads and inlet manifold,fit a different intake and runners,larger injectors and the list goes on.A decent 383 stroker like Lingenfelter is around $15000.
Old 01-18-2008, 11:51 PM
bobmic93
bobmic93's Avatar
My top end is brand new. Heads are 190cc, mods in profile. My cr is 11.3 and my cam has big overlap, which screws me on forced induction and 5to 7 grand is price for a supercharger(unit alone). Whats left? Stroker. Most 383 I see on this forum are well into the 400 hp tq range to the wheels.
To Turn a LT1 into a 383?
Quick Reply: Turn a LT1 into a 383?
