700r4 cooling line adapter
anyone know what type of Russel ( or other) adapter fittings I would need to use to replace my cooling lines? I am looking to fab up cooling lines using an-6 braided SS hose ( maybe an external cooler too).
I have a 79, with an 1989 l98, TPI, and 700r4 in it. And yes I like it very much. When I did the engine swap I put some temporary lines in that I need to make a little more formal. thanks for the input!
at the radiator? If so, then the following items along with suitable
hose might do the job.
- 4 pc - FBM2111: Aeroquip Adapters - Fitting, Straight,
-6 AN Male to 1/ 2-20 in. Inverted Flare, Aluminum, Blue
. - 4 pc - FBM1512: Socketless Hose Ends - Fitting, Straight,
-6 AN Socketless Hose Barb to Female -6 AN, Aluminum, Red/ Blue,
they are suitable for your purposes.
Are the fittings on the tubing at the transmission the same as those
Thanks I will look these up on Summits web site. And for the record both ends are not the same.
I have read some horror stories on other sites that well meaning individuals have actually cracked their transmission case doing this. So if there is room I think I will leave them there. Thanks!
I put the -6 AN fitting directly into the case with no problems. I believe it was a pipe thread. ou can remove the brass fitting and have it matched. It was a common fitting and is working well with no problems. I love my 700R4.
Best money I have spent on the vette. It drives so much better than the th350.
I have seen it may times. Use no sealer on the pipe thread that screws into the trans case.
I have seen factory fitting, and aftermarket fittings crack the case when tape or sealant is used.
Even if I have been sniffing glue, and am dead wrong, it is worth trying.
I assume it was a hydraulic situation that did it.
