L83 cam specs
Those two properties aren't mutually exclusive. There are solid lifter flat tappet cams, hydraulic lifter flat tappet cams, solid roller cams, and hydraulic roller cams. The L83 uses a hydraulic, flat tappet cam. No C4s came with solid lifters, flat or roller tappet. 1987 and up engines use hydraulic rollers.
RACE ON!!!
RACE ON!!!
Location: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by xrcrx
The L83 cam specs are 403i/415e @ 50. 202/206 duration, flat tappet hydraulic
Intake: .2733"
Exhaust: .2820"
Times the 1.5:1 rocker arm ratio, equal valve lifts of:
Intake: .40995" (.410")
Exhaust: .423"
RACE ON!!!
