CDN-86 Bose Radio Repair?
Original Bose radio/cassette player in my late-86 Coupe. Lately the tone controls have been very 'scratchy' when trying to addjust the slides. Also the cassette has been 'kicking-out' of loaded/running tapes. Suspect I need belt adjustment/replacement work done? Any suggestions for reliable repair/rebuild shops for these early Delco/Bose units, preferably located in Ontario, orCanada? If possible I prefer to keep the original set-up. Thanks,friends!
Don't know of any north of the border, but have read good reviews from Dr Don's work.
http://www.doctordons.com/
Try these people. They also have a lot of useful information on repair, and removal of the Bose systems. www.carstereohelp.com
Slingshot
http://www.ecklers.com/product.asp?p...9&dept_id=1260
My 86 roadster was doing the same thing. It turned out to be the speaker relay. You should check out this relay before you yank out your radio and send it off for repairs. Here is where you can get one:
Hi
Try Custone Electronics in Whitby...they do a lot of auto electronics repair.
http://www.custone.com/cei/about_us.asp
Cheers
Gary
Cheers
Gary
Last I checked, the only authorized Delco/Bose repair facility in Ontario was Mass Electronics. Apparently, all Ontario GM dealers send any and all problematic Delco/Bose head-units and speakers to them for repair.
www.mass.ca
I should mention, it's been a while since I looked into repairing/overhauling early C4 head-units, so Mass Electronics may no longer be the only authorized Delco/Bose repair facility. Best bet would be to call and ask; the last I talked to them, the price they quoted was expensive!
And I'm sure that other electronics shops can probably repair your head-unit.
Good luck!
www.mass.ca
Good luck!
www.mass.ca
Good luck!
www.mass.ca
Good luck!
Slingshot
audio relay removal magic
so in kinda new but im having the same problem with my 86 coupe. i can see the relay and can barely touch it with my hands. the question is how all of you are able to remove it. i cant seem to get anything in there to do the trick. any suggestions?
Try and get your hands on the relay connector and unplug it, then install a new one and tuck it up into the dash.
To remove it from the dash support brace, will take a lot more work. As in removing the crash pad or dash pad.
Slingshot
I recently had the Bose stereo/tape player in my 86 roadster rebuilt. Dr. Don will not repair an early model Bose system, claims that he can't get the parts. He will however, steer you toward an expensive after-market replacement.
One of this Forum's members told me about Factory Car Stereo Repair in Florida. http://carstereohelp.com/bose.htm. They totally rebuilt my early model Bose unit and it now works just great. They also gave me a 12 month warrantee on the repaired unit. Check them out they are good people.
thanks, thats what i ended up doing. thanks for the help though
Slingshot
