Change Oil Light 1991 - turn off help.
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Just dealt with this one yesterday. Turn your ignition key to the on position (Don't start the engine). Press the "ENG MET" button on the trip monitor and release. Within 5 seconds, press and release the "ENG MET" button again. Within 5 seconds of step 2, press and hold the "RANGE" button on the trip monitor. The "CHANGE OIL" light should flash. Hold the "RANGE" button until the light stops flashing and goes out. When the light goes out, the engine oil life monitor is reset. If it doesn't reset, turn the ignition off and repeat the procedure. I had to do it twice on my '93. Got it the second time!
