she's started idling rough
Old 05-02-2008, 12:12 PM
19vette89
19vette89's Avatar
Default she's started idling rough
the other day my 89 l-98 just started idling rough. swinging from about 1200 rpm to 600 rpm. it was idling so rough that the car was almost shaking or quivering. weird, because i've never had an idle issue. could it be the ethanol additive that is being put in to gas now? i know when i first got the car, i found straight pins inserted in to the tps connector??? i removed them months ago and did not see any change in the idle. any ideas? the car has been through a complete tune-up. also, it has a new fuel pump and filter.
Old 05-02-2008, 02:04 PM
jspeakman17
jspeakman17's Avatar
im going through the same thing! i was advised to check the injectors. it seems to be the consensus around here, so thats my next move. i replaced everything too, and im in the same boat! read some of the other threads for more details. it will help! good luck!
Old 05-02-2008, 02:12 PM
1989vette
1989vette's Avatar
Sounds like its a miss. Best thing to do would be to ohm every injector, and make sure every cylinder is getting spark. Make sure all 8 wires are good and producing spark.
Old 05-02-2008, 02:16 PM
seenalot
seenalot's Avatar
last November my 1989 started idling rough and hesitating. My injectors were replaced previousily when the car was throwing out codes, none this time so tried dry gas and injector cleaner. Nothing help so put it into storage for the winter. Started driving it late March, after a few fill ups the condition improved where its running like new.
Could be bad gas. Also never overlook the injectors but mine were throwing codes, neither of you are mentioning codes.
Old 05-02-2008, 03:48 PM
bd2626
bd2626's Avatar
A real quick thing to try is a shot of TB cleaner in the TB and see if the idle improves....TB may just be sticking, then maybe a vaccum leak?
To she's started idling rough
Quick Reply: she's started idling rough
