What are the specs for a stock L98 and LT1 cam?
Re: What are the specs for a stock L98 and LT1 cam? (Thad)
Here's the LT1 and LT4 info...
http://home.tir.com/~steveher/lt4.html
You can find most all the cam specs referenced in the catalog on the GMPP page:
https://www.spoperformanceparts.com/
drj
[Modified by DOCTOR J, 12:34 AM 12/17/2001]
drj
Cruise-In II Veteran
That GM site didn't have an '88 L98 cam and it differs a little from the '87 listed so here it is:
Lift=.410"/.423" w/ 1.5:1 rockers
Dur=211/219 deg @.050”
LSA=115 deg
LSA=115 deg
Re: What are the specs for a stock L98 and LT1 cam? (65Z01)
here is what i show:
350 TPI: part number 14093643
int ex
.403/.415 lift
202/ 206 duration @ .050
115 lobe sep
LT1: part number 12551705
int ex
.447/.459 lift
201/ 208 duration @ .050
116 lobe sep
int ex
.403/.415 lift
115 lobe sep
int ex
.447/.459 lift
116 lobe sep
Is that true, the '88 has a bigger cam? Or is that '88-up cam. Looks bigger than it should be to me.
BTW - I have an '88 L98 in my '91.
Scott
Scott
