infl rest help
Old 05-21-2008, 11:03 PM
gvrabac
gvrabac's Avatar
Default infl rest help
I had an o-ring go on a injector and had to get the car towed due to a gas leak. know I got the car home and replaced the o-rings and that was all good. but know my infl rest light and seat belt light are on. I've read the posts but the only thing I did not find was were the sensors are located. can anyone help me out. thanks
Old 05-22-2008, 10:42 AM
gw962
gw962's Avatar
The sensors are on the frame, one under the battery and the other under the AC/Heater box.
You might try resetting the codes first. If that doesn't work and the codes pop up again, you'll probably need to clean the grounds on the sensors. Check the archives for some really good tips on resetting codes and checking sensors.
Quick Reply: infl rest help
