Is this a Opti spark problem?
Further update.... I had the new Opti installed, a cost of $450 and it turns out that the new Opti is defective also. Now the car starts, runs for about 30 seconds and die's (like it was just turned off) it starts right back up again and runs for about the same amount of time then dies again. After the 3rd or 4th time it will stay running and run fine, so i drove it for about 20 minutes ( it was running fine) then it kinda sputtered once so i headed back home to avoid pushing/towing but let it run in the garage for amother 20 minutes without problem. (note when it first starts the check engine light is not on until it stalls then it sets a code 36) I can start it and give it gas so i wont stall and i can keep it running but it eventually sputters and then the check engine light comes on again. I remover the ECM fuse to reset the code, ( i think this is the correct way to reset) and the code is still there. These Opti's are a pain in the rear, and i looks like i'm gona learn how to replace them myself this time!!!
My 92 starts fine, and runs good for about 10 miles then it starts to miss and sputter, then die. I can restart it but it still misses and sputters. If it sits for a length of time (prob long enough to cool off) it will start and run fine for about 10 miles, then it starts missing again.
Could this be the Opti Spark? That is what the Dealer told me and they want $1500 to replace it and the water pump! Not to sure about the dealers work, and I would hate to do the replace myself and find it's not the opti!!
Thanks!!! :cheers
Well, here's my update. I installed the new ICM and the problem is still there. I checked the codes and im getting a code 36. Any help with a code 36? My repair manual says Code 36, Ignition system circut error or transaxle shift problem. I just replaced the ICM????
Thanks!!
Thanks!!! :cheers
Thanks!!
1 Post
Any codes? Doesn't sound like the opti to me. Sounds like an ECM problem. Have you tried putting a bag of ice on the ECM and seeing if it will run for longer than 10 minutes like this?
check all the plug wires. I had trouble starting. Dealer told me it "appeared" to be the opti. I had it towed to another shop and it turned out to be a loose wire.
good luck.
good luck.
Thanks!!!
Thanks!!!
Runs like a champ now and feels as if it has 20 additional HP.
1 Post
BTW, if it is an ECM problem - good luck. The 92 ECM is like the holy grail of parts for this model. You are more than likely looking to get a rebuild and even that can take a while.
I'm thinking that it has to heat up then it starts acting up and when it cools off its good again. Opti? For the price of the Opti, i don't want to just replace it and find it's not the problem.
Thanks for the input, But it will run fine for about 10 MILES, then start acting up, then after it sits for a short time, it will run again.
St. Jude Donor '05-'06
You need to check the things already given you before you go to the opti. The ECM, ICM and coil all will get flakey as the car heats up. The opti usually does not it either works or does not. If after you have checked the above and ruled them out then start looking at the opti. My bet is ICM.
Supporting Vendor
Thanks!!!
Thanks!!!
http://forums.corvetteforum.com/show....php?t=2055067
The Ignition Control Module is mounted to a aluminum heat sink on the right head above the coil.
Autozone and other places test them free, I really don't know if its just a static test or actually under load though. My experience with ICM's has always been total failure, not on again off again.
Does the car ever go into Limp Mode?
