Fixed loose interior door panel
I have been living with the loose and squeaking passenger door panel for about a year now and decided to figure out a fix.
I had previously pulled the panel and put the "L" backets on top of the door, which helped but did not fix.
So I pulled the panel again and found an "ear" on the latch side of the door that is behind the panel when the panel is on. This "ear had a hole in it, so I slipped a plastic screw retaining nut in the hole, drilled a hole through the panel to the plastic nut, and screwed it down.
The panel is staying put and no more squeaking!!
