Air inlet tube to throttle body
Some time ago some one made a air inlet tube between the air filter and the throttle body, made of silicone rubber. Its claim to fame was that it replaced the accordian type inlet duct with a smooth molded silicone hose to fit on the 90/91 speed density L98 cars. Does anyone here know where I can find one or someone that has one for sale. I have just installed a new SuperRam on a customers L98 car, with a new 58mm TB and the stock accordian style inlet duct will not fit over the new TB.
I have a 58mm TB and the stock intake fits OK.Those horrendously expensive silcone intakes are another example of snake oil salesmen. About as effective as an air foil.Try warming the original with a hair drier or heat gun.Should slip right on there.
...on my 96 the stock coupler worked fine with the 58mm TB after the application of a some silicone grease to the inside of the coupler....don't know if this is true for a L98 tho
Couple of minutes with a file solved my "fitment " problem.
Samco made these......check out this table...it is listed on the 6th line
http://www.samcosport.com/usa/car_ki...make=Chevrolet
Not sure who sells them....pretty sure Lingenfelter did at one time..
...but if the stock one doesn't fit, the replacement for stock won't fit either??
If in fact there is vacuum in these couplers it indicates something like a dirty air filter or woefully inadequate air filter or some other undesired restriction in the air inlet path....
BTW I also recall some reports that the cheap couplers have a seam that sometimes splits and allows unfiltered air into the engine..
I have seen this reported before.......but there should never be vacuum in these couplers on a properly functioning system!!!
The according style was rigid. I bought a modified air box and since I am running a MAP system, I use a '92 LT1 bridge. Once the engine compartment heats up, it turns very pliable. I use a K&N filter that is always clean. Not sure what else in line to the TB would cause a restriction
