Fuel pump relay location on my 94
5th Gear
Thanks for the quick reply. i was surfing the net for the same question. the answer i got was the same as yours. under the passenger side knee bolster. what i read was that i have to tear apart the vent system and remove the fuse panel to get at it. my service manuals don't give you a lot of help. My car dies on the freeway. I thought it was a heat issue but i ran it in my garage until the temp pegged out. ran like a top. i now believe that it is this relay or worse a loose wire for the pump. i was able to determin that the pump quits. (and yes, i just replaced the fuel pump) It only does this when i am in motion. i sit for a few seconds and she starts right up.
St. Jude Donor '05-'06
IIRC you can get to it without the teardown it is tucked up in the IP but you can reach it from below.Bolster was the only thing I took out to get to mine when I changed it.
