1986, fuel pressure regulator - vacuum connection
Old 08-20-2008, 05:24 PM
idcard
idcard's Avatar
Default 1986, fuel pressure regulator - vacuum connection
My 86 seems to run fine while I am driving it. The problem is at idle is wants to surge 400 - 700 rpm. The fuel pressure is 38-39 psi at the valve, but it drops about 8 lb in 1 min. and about another 4 after 2 min. with the engine off. I have read other threads that say check the injectors if this happens, but all have been cleaned and tested a Cruzin Performance and were all fine - he even cleaned the 9th injector. I can't fine in the FSM anything about the vacuum connection on the regulator. how do you test it? With the engine off, it won't hold any pressure using a hand vacuum pump. I have tested the EGR system and it seems OK and no vacuum leaks. Is the regulator vacuum causing the problem.
Old 08-20-2008, 05:38 PM
MK 82
MK 82's Avatar
Could be. Diaphragm may be broken. Do you smell gas when you remove the vac hose?
Old 08-20-2008, 05:52 PM
SAY WHEN
SAY WHEN's Avatar
If you're using a known good vacuum pump and have a tight connection on the pump and regulator nipple--the diaphragm in the regulator is bad--replace regulator--you would usually have raw fuel on the vacuum side either around the nipple or in the vacuum hose--will usually cause a multitude of driveability problems--such as difficult HOT starting.
Old 08-20-2008, 10:26 PM
idcard
idcard's Avatar
Thanks for your help. I will change the regulator. Does anyone know what the vacuum does to the fuel pressure regulator - increase vacuum will increase fuel available to the rail?
Old 08-20-2008, 11:27 PM
rodj
rodj's Avatar
"it drops about 8 lb in 1 min. and about another 4 after 2 min. with the engine off."
Or the non-return valve on the pump is worn allowing pressure to bleed off on supply side.
When you have the idle surge , does indicated fuel presure change also?
High vac (idle) closes reg reducing fuel ; low vac (accel ) opens reg increasing fuel.
Old 08-21-2008, 03:44 PM
MK 82
MK 82's Avatar
It's the other way around. Low vacuum under acceleration raises fuel press app 5 psi.
Attach your press gauge with the vac tube attached and the eng at idle. Remove the tube. The press should rise.
To 1986, fuel pressure regulator - vacuum connection
Quick Reply: 1986, fuel pressure regulator - vacuum connection
