Where is the MAF burnoff relay? 1987...
Is it under the ECM?
I started the car today ( after the first cold day here, 39 ºF ), SES, code 36, MAF relay.
Re: Where is the MAF burnoff relay? 1987... (Smash)
Thank you.
I just fixed it. I took both of hte relays apart, cleaned and adjusted the contacts and put them back together...works great, no more codes.
Funny thing is they looked brand new and one mount bracket screw was missing...I wonder if someone already changed them once? They sure are flimsy inside for such heavy duty looking parts.
Re: Where is the MAF burnoff relay? 1987... (BBA)
Might be better to replace them since they are only a $10 part.
I tried cleaning the relays and they worked fine for a little while.
Vic
Vic
