1990 corvette horn relay
Old 09-09-2008, 08:43 PM
jfva
1st Gear
jfva's Avatar
Default 1990 corvette horn relay
Need help
where is fuse and horn relay at on 1990 corvette conv?
Old 09-09-2008, 09:22 PM
rodj
rodj's Avatar
Fuse panel is in end of dash ,pass side ;hidden when door closed.
Horn relay is under the dash somewhere from memory.
Old 09-09-2008, 09:29 PM
C41987
C41987's Avatar
http://www.autozone.com/N,4294931136...locsSelect.htm
on my 87 the fuse was w/relay
Old 09-09-2008, 10:14 PM
BADDUCK
BADDUCK's Avatar
Location: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by jfva
Need help
Horn relay is behind the info panel in the dash above the shifter.
Old 09-10-2008, 10:09 AM
josephf31
josephf31's Avatar
Default On my 91
the horn relay is up under the passenger side dash hush panel, there are 5 in there altogether
Old 09-14-2008, 01:33 PM
pipe
pipe's Avatar
Yep under the pass. side hush panel. Laying on your back there will be 2 on the left together then a group of 3 on your right. It's the middle one in the group of three. Ya know sometimes it's not the Horn relay that goes bad not making the Horn not work. A small connector in the Steering Column gets brittle over time and cracks not making contact and causes the horn not to work. Pipe
To 1990 corvette horn relay
Quick Reply: 1990 corvette horn relay
