Speedometer works, odometer doesn't.
Old 10-11-2008, 03:31 AM
car5car
car5car's Avatar
Default Speedometer works, odometer doesn't.
What is voltage feeding odometer motor? How to check it? Manual says to use some special electrical device. Can I buy motor for odometer?
Old 10-11-2008, 10:29 AM
lt4obsesses
lt4obsesses's Avatar
Let me get this straight, you drive the car and the speedometer works fine, but the odometer is not counting the miles? I think in this situation you should...:
Sorry, seriously I have no idea.
Old 10-11-2008, 01:17 PM
car5car
car5car's Avatar
Well if this is what you want you can disconnect odometer connector from instrument cluster but this is illegal. My cluster has mechanical odometer and electronic cluster. I need to check it out maybe this is what previous owner did.
Old 10-12-2008, 09:06 PM
lt4obsesses
I was only kidding. I had read where the milage was recorded to the ccm. There were some threads about this awhile ago. Personally I want every glorious mile I drive to be accounted for.
To Speedometer works, odometer doesn't.
Quick Reply: Speedometer works, odometer doesn't.
