The NEW Official Timeslip Thread
#241
Somebody new needs be in charge of updating this thread. It hasn't been updated in a long time. I ran a 9.87@142.24. It had a 1.480 60ft, 4.166 330ft, 6.369@111.16 half track, 8.287 1000ft. 9.876@142.24 quarter mile. DA 6300ft
#243
This is so crazy lol I just got done watching some fb clips from this past weekend at Keystone. I come here and find your car lol Small world!!!
#244
My new best after installing my LT, H pipe back. NO internal mods. (73) if I can pull 1.9's easy 12's
108.68 best MPH. best 60@ 2.111
#245
1985 C4. ZZ4 roller motor, 9.27:1, with 211/219 LING cam, AFR 195 with 65 cc chambers, full length headers with 40 series flows, no cat, super ram, TJwong chipped (from old setup), 92 octane, 2200 full lock-up converter, running MT ET street drag radials 255/50R16. Full tank of gas and spare tire on board. With less gas, no tire and drop the pressure down on the MT's to 15-20 so it actually sticks, and chip the new setup, I think low 12's are in the future
12.66 @ 108, 1.86 60 ft Portland International Raceway
#246
Pro Mechanic
This is a bit different...but still smokin'.
#249
With the IRS and DM Flywheel it went 13.02. Not much quicker with the 9". I think the 35 spline axles and heavier driveshaft slow it down.
#250
Car-1992 M6 Kind of stock with LT headers, 1.6 rockers, tune, aluminium flywheel. Rear is a 9" with 4.11 and 315s M/T DR
Drove approx 130 miles each way.
12.84 ET at 108 MPH at Atco Dragway. 11/13
Hope to have ProCharger installed for next season.
Steve
Steve
#251
ET Slip 11.00
IMG_0439.pdf
This et slip is from Brainerd MN May 2016
DA 2375'
383 Stroker all forged
TPIS dyno tune
52mm TB
TPIS mini ram
ZZ409 roller cam
1.6 Rockers
Dart pro1 heads
TPIS long tube header
PATC 700r4 trans w/power gear and 2800 stall
D44 3.45 ratio
MT 28" DOT slicks, mini's up front
DA 2375'
TPIS dyno tune
52mm TB
TPIS mini ram
ZZ409 roller cam
1.6 Rockers
Dart pro1 heads
D44 3.45 ratio
#252
..... Yesterday @ Lakeland Dragstrip FL (1-28-17) .....
6.65 1/8th 101.85 mph ... 87 ... 421sbc Brodix 227cc heads , Hooker LT's with 3" full exhaust X-pipe and 50 series Flowmasters , TH400 4500 stall Vigilante T/C , D44 IRS w/4.33 gears and True-Trac , E-85 , M/T ET Drag Slicks 26x10.00 ... car is still registered and occasionally street driven .....
#254
96 LT-4
58MM Throttle body
TPiS MAF housing halves
Intake port matched to 7777
Stock heads and valves
Lloyd Elliott Custom cam
Mechanical water pump delete (SBC timing set)
bored 030
Manley H beams
JE 2618 pistons, file fit rings, 11:1
ARP studded head and mains
MLS head gasket, 040 quench
42 lbs injectors
Stock ZF-6
Stock dif
C7 rims, 305/35x19 Nitto NT05R
58MM Throttle body
bored 030
Manley H beams
42 lbs injectors
Stock ZF-6
Stock dif
#255
My 93 auto. 3.73, drag radials, full header, 3200 stall, 180 Afr heads ported and polished by TPIS, ZZ9 cam. I thinks that's it, best run 12.2 @ 115.
#256
96 LT-4
58MM Throttle body
bored 030
Manley H beams
42 lbs injectors
Stock ZF-6
Stock dif
58MM Throttle body
bored 030
Manley H beams
42 lbs injectors
Stock ZF-6
Stock dif
#257
#258
#260
Old data but still data
1984 A4 D44 with 3.54
May 2008
Stock shortblock. AFR 190 heads. HSR. Garrett TBP7501 Turbo. 4L80E. Vigilante converter. E85 fuel.
60 ft - 1.827 s
1/8 mile - 7.245 s, 105 mph
1/4 mile - 10.862 s, 134.5 mph
June 2018
Dart litte M 4.125 bore. 3.48 stroke. 372 CUI. AFR 190 heads. HSR. Garrett TBP7501 Turbo. 4L80E. Vigilante converter. E85 fuel. MaxxECU
60 ft - 1.5421 s
330 ft - 4.1968 s
1/8 mile - 6.3415 s, 116 mph
May 2008
60 ft - 1.827 s
June 2018
60 ft - 1.5421 s
330 ft - 4.1968 s
lt4 coupe (01-21-2020)
