The NEW Official Timeslip Thread
My LTR setup ran a best of 13.228 at 102.335 with a 1.876 60', 1/8 mile was 81.817.
Mods: '88 Corvette coupe, auto, 3.07, A/O intake, K&N, free mods, ported plenum, ported TPIS big mouth base, AS&M runners, TPIS headers, March under drive pulleys. Dual exhaust with H-pipe. Edit, street tires, KWD.
Location: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
1 Post
1/4 11.26@123
1/8 7.18@95
60' 1.581
95 auto/w 396 lt4 stroker,AFR 195s,Hyd.230/236 cam,58mm T.B., 36lb.inj.,
2800 stall,Dana 44, 3.73 gears, DR's. DA +800 in March 07
1/8 7.18@95
60' 1.581
Former Vendor
Also why isn't this a sticky?
lucky...........the track was so sticky that pass that i was waiting for something to snap....the tires didn't spin at all. i knew as soon as i punched it i was gonna have a good run. my next closest 60' was 1.99. i only ran it at the track about 6 times and the other 60' times are in the 2.05 to 2.20 range
89 Vette , 11.32 at 119.96 (Da -200), 1.52 60' time , Stock 350 bottem end , Ported 113 heads , ZZ9 Cam, 700R4 Tranny, Dana 44 with 3.73 gears
#33
Charlie Lamar, 84 Corvette 383 carb, cam, dart pro 1's,11:1 compression, lightened rotating assembly, 3600 stall, 700r4, 3:73, a-mod 315-35-17's, Street tires.
1/8: 7.72 @ 89 mph, 1.7 60 ft
#34
The New Official Time Slip Thread
85 Vette; 60 ft. 1.52; ET 11.31, 120.68 1/4mi ; 7.22, 92.38 1/8th mi ; 406 ci ; TFS out of box 195 heads, TPIS MINI RAM, 58mm Throtle Body; TPIS ZZ9X HYD ROLLER CAM; ROSSLER 700 R4; 4000 stall 4.10 dana 44 TPIS HEADERS & CAT BACK SYSTEM; MT ET STREETS
Last edited by 85C4sX2; 10-29-2008 at 10:35 AM. Reason: ADD INFO LEFT OUT ON ORIGINAL POST
#35
R/T.....0.749 s
60'......2.170 s
1/8.....9.066 s @ 80.84 mph
1/4.....13.989 s @ 100.96 mph
(Temperature around 75-80 F)
Stock '91, 6-speed manual with 3.45 gear D 44, stock mufflers, street tires. K&N air filter with open lid, EGR removed, A.I.R. pump gutted, frisbee removed, throttle body coolant bypass, dual exhaust without precats.
60'......2.170 s
#36
St: Jude Donor '10
Hello,
My information needs updating. Here is what you have for me right now:
13.62 @101 1.97 94 A4 3.07 LilRedCorv Borla muffs
And this is what it needs to be changed to:
13.50 @101 1.90 94 A4 3.07 LilRedCorv Borlas, 160 tstat, 2400 stall
Thanks!
Thanks!
#37
96 Auto 355ci with 3.73, LT4 hot cam, mez ewp, 2800 stall, 52mm tb, cai, DR's and a few minor bolt on's.
Best time this year but not the cars best.
60'........1.72
1/8 .......7.80 @ 88.7
1/4 .......12.184 @ 115.76
Run 10/18/08 cool 55 deg. day.
60'........1.72
#38
Ok, I am still learning about 'how to do it right'. 95' Coupe, LT1, A4, 3.07 rears, Drs and elims, Meziere WP, otherwise bone stock.
1/8th mile track, air temp 75*F
60ft 1.99
Trap 8.62 at 85 mph
60ft 1.99
Trap 8.62 at 85 mph
