The NEW Official Timeslip Thread
Old 10-12-2008, 11:02 PM
MTVette
MTVette's Avatar
Default The NEW Official Timeslip Thread
Updated 8/22/11
Notice to all CF C4 owners and drivers:
I've volunteered to take over the administration of this list for the group. I've updated it as of the last page posted in the original thread here. I'll continue to update the list as frequently as needed to keep it current.
Post your best times, and your trap speed and 60ft for that run, and density altitude of the air if you know it.
List your year, mods, gearing, and transmission, or you may not be added to the list.
And if you 1/4 mile guys could put some 1/8th mi info up, the rest of us without full tracks would be very grateful. You can also post your older best times with previous setups. My intent is that people can use this as a general reference on what to aim for with certain setups.
1/4 MILE, 11's and faster
Code:
  ET   MPH 60ft  D.A.     CAR       MEMBER   MODS
 8.3  @169 1.30        86 A2 3.73 tensecvet  Bammann 565ci, Carrolls Rod & Racecraft Bolt-in rear, glide, some rims & 350 shot
 9.34 @153 1.82        87 M6 3.45 AKS Racing 408cid , AFR215s, 248/254 @ 0.050 SR cam, SP intake, MB, D1R, FAST sequential, ZF
 9.54 @139 1.28        90 A2 4.56 hookedup   420, carbed, PG
 9.80 @135 1.54        92 A4 3.50 rwisk      346ci LS1, Melrose swap headers, 4l60e trans, 3600 stall, forged motor with d1sc procharger@14lbs of boost, Carrolls rod and racecraft straight axle rear with 28" et street radials
 9.82 @148 1.54        92 M6 3.73 97AGGIE    383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh
 9.88 @137 1.34        93         INSANITY   434, NA, turbo 350, solid rear
 9.90 @132 1.42        95 A2      dr.juice   383, 200 shot NO2, Powerglide, 28x10x15 Goodyear slicks
 9.91 @140 1.43        86 A4 3.92 REDC4CORVE 434ci, 1050 Holley, CompCams 325, 125 shot, DRs
10.04 @138 1.47        92 A4 3.50 rwisk      346ci, Melrose headers, 4l60e trans, 3200 stall, forged motor with d1sc procharger@14lbs of boost, Carrolls rod and racecraft straight axle rear with 28" et street radials
10.06 @135 1.39        84 A4 ???? vetjack    406 sbc on 175 shot
10.14 @137 1.43        95 M6 3.70 dr.juice   377ci, 9.5:1, 250shot, M&H slicks, AFR/TPIs heads, LT4 intake, LTs, 3" exh, Spec clutch, 4-link 9in, CCW drag pack
10.15 @134 1.37        89 A3 3.73 ski_dwn_it 434ci, 11.5:1, M/T slicks, m2race brodix t1 heads, single plane, 3" ex, 8" TC
10.16 @137 1.42        89 A3 3.73 ski_dwn_it 434ci, 150 shot, 3000 stall. 11.5:1, M/T slicks, m2race brodix t1 heads, single plane, 3" ex, 8" TC
10.27 @131 1.41        85 A4 3.07 CORKVETTE1 434ci, 11.5:1, solid roller, 4200 TC, single plane, monoblade TB, brodix t1 heads
10.33 @139 1.65        85 A4 3.31 SloRvette  398ci 4000 stall, Canfield heads, 242/254 sr cam, Hooker 2151 headers, dual 3" exhaust, XFI,  StealthRam, .024" jets in dry fogger, SRA Performance trans 4L60e full manual, Pro Torque 4500 stall non lockup
10.36 @136 1.52 +6800' 91 M6 3.70 tpi421vett 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9"
10.44 @133 1.53 +4400' 91 M6 3.70 tpi421vett 421 bowtie block, ported miniram2, AFR220s, NOS, comp mech roller cam, monoblade TB
10.53 @131             96 M6 4.10 d48mclain  398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake
10.53 @127 1.42  500'  84 A4 4.33 383vett    406ci, Cola crank, JE Pistons, Crane cam, Holley heads, SuperRam, 4L60e tranny, Strange  12-bolt
10.55 @133 1.55        83 A4 3.54 dan0617    383, 12.2 compression, 230/236 cam, AFR195's, HSR intake, 200 shot, 2800 stall, built 700R4, ET Street radials
10.72 @149 1.62        90 A4 3.33 SloRvette  398ci 4000 stall, Canfield 197's, 242/254 sr, Hooker 2151 headers, dual 3" exhaust, 58 TB, StealthRam, 100 shot dry plate, FAST XFI
10.75 @128             96 M6 4.10 jonecap    LT4 hotcam, 4.10's, headers, exhaust, ewp, Centerforce clutch, 150 shot nitrous
10.83 @134 1.82 +1200' 90 M6 3.91 mos90      396 solid roller, slicks, 250shot, mcleod RichS clutch, FAST xfi
10.89 @121 1.49        96 A4 3.75 RichS      396ci, DRs, morgantini heads, ported LT4 heads/int, 3600 TC, CompCam, DRM LTs, 58mm tb
10.90 @126 1.49 +2100' 86 A4 3.33 REDC4CORVE 434ci, MT streets, 1095 barry grant carb, LT4 exh,
10.93 @126             86    3.45  _TWISTED_ 383, TPIS MiniRam w 58mm TPIS TB, N2O, PeteK 700r4 build, D44, Hooker Headers w/ custom 3" exhaust into SpinTech's
10.97 @124 1.51        87         Pete K
10.98 @122 1.53        85    3.45 IHRA221    383 spool
11.01 @123 1.42        93         INSANITY   396
11.02 @126 1.60        96 M6 3.75 RichS      396ci, DRs, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb
11.05 @123 1.60        90         SloRvette
11.14 @126 1.72        84 A4L     JoBy       Garret turbo, I/C, DRs, Stealth Ram, AFR 190s, Comp 12-404-4, LTs
11.21 @122 1.56 +2200' 94 A4      REDC4CORVE 125shot, 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs
11.25 @119 1.55 +1600' 86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust
11.26 @123 1.58  +800' 95 A4 3.73 PDQUIK95   396 lt4 stroker, AFR 195s,Hyd.230/236 cam,58mm T.B., 36lb.inj., 2800 stall Dana 44, DR's.
11.31 @120 1.52        85 A4 4.10 85C4sX2    TFS 195 heads, TPIS MINI RAM, 58mm Throtle Body; TPIS ZZ9X HYD ROLLER CAM; ROSSLER 700 R4; 4000 stall TPIS HEADERS & CAT BACK SYSTEM; MT ET STREETS
11.32 @120 1.52  -200' 89 A4 3.73 Vic '89    Stock 350 bottem end, Ported 113 heads, ZZ9 Cam, Dana 44
11.37 @123 1.66  -500' 91 M6 3.90 neat       383, AFR heads, 230/236 cam, miniram, Mseven tune, nitto DRs, NA
11.55 @116 1.53   -90' 92 A4 3.33 MTVette    383 LT1, custom cam. ported heads & intake, LT's, 2600 TC, MT ET Street DR's
11.55 @123 2.1         85 M6 3.07 Killer408  drag radials, 406 sbc, afr heads, super ram intake, long tube headers, Mcleod street pro clutch, Accel efm (base tune)
11.57 @119             84 A4 3.08 NXS        9.5 compression, 230/230 cam, 70mm turbo 6 psi, street tires, full exhaust, pump gas
11.59 @117 1.66        91 A4 3.45 twin540    383 stroker afr 195 eliminator, LT1 intake conversion 503 cam built tranny with 5 pinion planetary front/ back. 3.45 dana 44 9.5" 3000 stall converter on 315 mt et drag radials
11.61 @119 1.76 +1600' 93         steve40th  425 rwhp 417 ft/lbs tq
11.62 @122 1.78        86 TKO     ol,RJ      406ci solid roller, victor E intake, brodix heads, 246/.542cam, LTs, tune, Toyo RA1
11.64 @105 1.57        93 A4 3.73 93lt1fun   396 stroker LT1, GM 846Cam, ported LT1 heads, 52mm throttle body, Meziere water pump, TPiS LT headers, RT cats, 3500 stall Vig TC, MT ET Street DR's
11.71 @117 1.69        93 A4 4.09 93 ragtop  MT et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune
11.77 @114 1.67        86 A4 3.07 jd_v3tt3   150shot, BFG DRs, LTs, elims
11.79 @118 1.56   983' 93 A4 3.73 1989TTATony 383 LT1, 2800 TC, MT DRs, 1.6RR, Corsa cat-back, PCM4less tune, LE2 ported heads, custom cam
11.87 @113 1.68        95 A4 3.73 ckp        D36,3000 TC, 30lb Ford racing injectors, Bottom feeder air induction, Pro Flow XT intake, Wilson 90mm TB, Headers, Stock mufflers, skinnies and cheater slicks
11.89 @120 1.9         96 A4 3.07 Dan Parker 75 shot, Nitto DRs, 3000 stall, LE2 heads/cam, EM LTs
11.94 @116 1.67        93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune
1/4 MILE, 12's
Code:
12.03 @116 1.67   50F  96 A4 3.73 vettestir1 LT4 hot cam, mez ewp, 2800 stall, 52mm tb, cai, DR's and a few minor bolt on's
12.05 @115 1.76        96 M6 4.10 jonecap    DRs, EM LTs, R/T cats, catback, tune
12.08 @116 1.94        90 M6 3.73 adi4       383, miniram, 224/234 cam, 1.52 RRs, trickflow 195s, 54mm TB, EM LTs, RT cats, Corsa, alum fw, MSD
12.08 @112 1.63        95 A4 3.73 cheetah    Headers,TC,coilovers,Eradispeed Plus rotors,CompCam,Lingenfelter headwork,PCMforLess(ish) tune, homebuilt ramair, 52mm TB,bullet cats,x-pipe thru stock mufflers, 30lb Ford injectors, adj. Camaro fuel pressure reg
12.13 @120 1.93        86 TKO     ol,RJ      406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune
12.19 @108 1.62   80F  86 A4 2.73 vetster86  Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs
12.19 @114 1.76        96 M6 4.10 jonecap    LT4, DRs, catback, tune
12.22 @112 1.74        96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's
12.23 @111 1.69    83' 92 A4 3.73 reoch999   CC503 cam, 1.6RR, Flowmasters, 3000TC
12.24 @116 1.96        96 A4 3.54 fredk      190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune
12.24 @116 1.96        96 M6 3.45 tpivette   LT4, hotcam, cut lid, elims, port matched intake, 5-angle valve job, tune
12.25 @112 1.84        90 M6      j-stingray 355 cu in, nitrous, lingenfelter intake, 58mm TB, hypertech chip, 1.6 RR, hooker headers, flowmaster catback
12.27 @111 1.77        94 A4 3.45 blue94     AI ported Heads, 565 lift 110 LSA, 2800 Stall, LTs, MT ET's, D44
12.28 @110 1.65  -460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels
12.31@112 1.87        88 A4 3.07 Aardwolf   Ram air intake, K&N, free mods, ported MR, ported head, TPIS headers, March under drive pulleys, dual exhaust with H-pipe, street tires, KWD
12.34 @109 1.74        89 A4 3.07 dustmann   383, ATI supercharger w/8 PSI boost, ported intake & heads, comp cam, MSD ignition, Nitto DR's
12.34 @113 1.82     0' 90 M6 3.33 bogor      vortech s/c 8psi, ET streets superram, mild cam, LTs, 52mm TB, Autotronic SMC
12.37 @115             89 M6 3.33 vette punk 383, Superram, DRs, 1.6RRs, pulleys 58mm TB, LTs, 3.5" ex, chip, SLP cai, LPE 219 cam, AFR 190s
12.41 @109 1.87     0' 91 M6 4.09 neat       100shot, ET streets, Hooker LTs, catback
12.42 @114 1.97        96 M6 4.09 Dr. Evil   hotcam, catback, K&N+cutlid
12.43 @117 1.79        90ZR1      MFS        hooker mufflers
12.49 @108 1.63        91 A4 3.33 TA         stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs
12.50 @108 1.67        93 A4 3.45 Mr Mojo    2800 TC
12.51 @107 1.68  +800' 92 A4 3.33 MTVette    M/T DRs, 2600 TC, LTs, hotcam, chip, 1.6RRs, RT cats, Xpipe
12.58 @114 2.17        85 M6 3.45 LD85       406ci, AFR 210s, Miniram
12.62 @109 1.85        96 M6      1stvette94 BFG DR's 1.6RRs, Meziere
12.62 @110             84 A4 3.07 NXS        350 dishtop, ported vortecs heads, airgap intake, 2.5" exhaust with x-pipe, toyo tires, ac delete
12.63 @111 2.01        96 A4      Legion21   SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI
12.65 @114             95 M6      gears      hotcam, ported heads, ed wright chip, 52mmTB, tpis LTs, catback, vortex rammer
12.66 @108 1.83   100F 90         skateparkd M/T DRs, Hooker LTs, Monza muffs, Catless, 125shot, Jet Perf stg 2 chip, 160stat, Manual Fan Switch, Tossed frisbee
12.68 @108 1.86        89 A4      Chance     383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals
12.72 @107 1.77        94 A4 3.55 GS4-LT1    ZZ-409 TPIS Cam, TPIS 52mm TB, 1.6 RR, TPIS AFPR, 3000 stall converter, Dana 44, Hoosier 315 DR's. Stock heads, intake, fuel pump and injectors.
12.74 @110 1.96        96 M6 3.91 C4DC       LT4 CE K&N w/ cut lid, SS Works LT headers, RT cats, Corsa, Hurst, Camber Brace, ZF Beam Plates, Z51 HO shocks, Poly rear end/swaybars
12.76 @104 1.80        87 A4 3.54 stauger    383 LPE
12.81 @113 2.10 +2300' 88    3.73 88espo     358ci carb
12.83 @107 1.84        87 A4 3.07 SpankYello 180cc intake heads, Miniram, ZZ4 cam, LTs
12.85 @106 1.90        89 M6 3.33 Razor89    nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip
12.87 @109 1.87        92 A4 2.59 04gtogoat  Hotcam, 1.6R, full exhaust catless, elims, power coupler, MSD blaster, 30# injectors, stock block, convertor, & tune
12.89 @111 2.09        93 M6 4.09 DieL       1.6RRs, pullies, crane hi-6, accel u-groove plugs, Watson headers, no cats
12.89 @106 1.74  1702' 93 A4 3.07 1989TTATony 2800 TC, MT ET Streets, 1.5RR, Corsa cat-back, PCM4less tune, K&N w/cut air lid
12.90 @105 1.73        89 A4 3.07 HeeHaw89   355, LPE/Accel base, LPE 219, AS&M LTR, ported plenum, ProMag 1.6's,Hooker 2149's, 24lb inj, Holley AFPR, Magnaflow cat, LT1 mufflers, Vigilante 2600, B&M cooler, Nitto dr's, free mods
12.91 @110 2.09        96 M6 4.09 Dr. Evil   hotcam, catback, K&N+cutlid
12.93 @107 2.00        94 M6      pr1mu5     DRs, centerforce clutch, no muffs, no spare tire
12.95 @107 1.93        96 M6      ubnpast    DRs, SLP intake, flowmasters
12.95 @108             84         elkabong   rollerblock w/ Eagle internals, trickflow heads, 10.4:1, Comp XR269 cam, 1.6RRs, X-Ram, EM LTs, 7747 ECM
12.95 @108 1.99        89 M6 3.54 89sleeper  M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom
12.98 @108 2.20        87 A4 2.59 CRV3TT3    Paxton S/C, exh, M/T DRs
12.98 @108 2.12        91 M6 3.64 sebaj      355 Miniram, Edelbrock heads, Hotcam, 1.6RR, Alvin tune, Bridgestone tires12.98 @102 1.78    68F 87 A4 3.07 rodj       M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB
12.99 @107 1.95  -500' 95 M6 3.45 Mr Mojo    no muffs
12.99 @104 1.77        86 A4 3.07 jd_v3tt3   BFG DRs, LTs, elims, stock iron heads
12.99 @101 1.70        87 A4 2.59 JimMcCombe 377 stroker, Edelbrock heads, Crane cam, 2500 stall TC, 52mm TBK TB, Goodyear Eagles
1/4 MILE, 13.0-13.5
Code:
13.00 @107 1.95        94 M6      pr1mu5     DRs, centerforce clutch, no muffs
13.01 @107 1.97        94 M6 3.45 1stvette94 DRs, 1.6RRs, meziere
13.02 @107 1.90        92 M6 3.45 STEVEN13   Stock with Tri-Y LT headers, 1.6 Rockers, Tune, Toyo 888 scrub road race tires
13.04 @106 1.96        91 M6 4.10 neat       LTs, catback, 1.6RRs, tune
13.07 @108 2.07 -2150' 95 M6 3.45 Mr Mojo    stock
13.07 @105 1.96        92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip
13.07 @102 1.83  -400' 88 A4 2.59 65Z01      TC, SLP cai, 52mm TB, ported plenum, no precats, cat&back, 1.6RRs
13.10 @109 2.06  +500' 93 M6 3.45 mn_vette   iron heads, no cats, mez, 58mmTB, 230/236 cam
13.11 @108 1.91        90 M6      jonecap    DRs, TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys
13.11 @107 1.90        87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs
13.14 @106 1.97        89 M6 3.33 black_89_v 383, Superram, LTs
13.14 @107 1.97        96 M6      Jack_lt4   flowmaster
13.14 @103 1.91        89 M6 3.33 Z51L9889   ported 113s, no precats, cat&back, portedTPI
13.17 @104 1.99  -400' 88 A4 2.59 65Z01      SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs
13.18 @103 1.79  +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC
13.21 @103 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties
13.22 @108 2.00        85 A4 3.07 JohnMarker ZZ4, LPE 74211 cam, AFR 180 heads, SuperRam base, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, TRANSGO shift kit, 2400 stall
13.22 @107 1.95 +2771' 92 A4 2.59 04gtogoat  hotcam, 1.6RR, CC full exhaust catless, eliminators, power coupler, MSD blaster, 30LB injectors
13.23 @107 2.12        94 M6      1stvette94 stock
13.25 @111 2.6         96 A4 3.07 Dan Parker LE2 heads/cam, EM LTs
13.29 @108 2.21 -2150' 94 M6 3.92 DaveT      just gears
13.29 @105 2.04        89    3.07 kopbet89c4 miniram, no cats, chip, 24# inj, no MAF
13.32 @109 2.21 -2150' 95 M6 3.45 Mr Mojo    stock
13.34 @ 99 1.82        85         black85    LTs, catback, pulleys, ported TPI
13.3  @106 2.0         87 M4 3.07 TUNED87vet 1000cfmTB, ported plenum, bigmouth base, AFRs, TPIS cam, LTs, cat+back, tune
13.37 @102 1.95        93 A4      Mr Mojo    stock
13.38 @104 1.94    60F 95 A4 3.07 pettvette
13.38 @107 2.06        86         PaulRugger factory aluminum head, 1.6 roller rockers, MSD ignition, Toyo R888 tires
13.4  @108 2.19 +1500' 90ZR1 4.10 cuisinartv 3" exhaust, Haibeck chip, meth injection
13.45 @102 1.86  1200' 89 A4 3.74 Red98C5    D44 - Hedman Hedrs - Flowmaster 40 Series - BFG 275/18
13.47 @101 1.95        93    4.10 Driftmonst LTs, chip, borla exh
13.49 @102 1.94        92 A4 3.54 mcnulty95  shift kit, elims
1/4 MILE, 13.5 and slower
Code:
13.50 @101 1.90        94 A4 3.07 LilRedCorv Borlas, 160 tstat, 2400 stall
13.50 @101 1.99  -500' 88         65Z01
13.53 @103             95 M6 3.45 95_6spdvet
13.54 @107 2.24 +2445' 91 M6      neat       100shot, Hooker LTs, catback
13.60 @102 1.95 +2200' 94 A4      REDC4CORVE 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs
13.61 @ 99 2.09        85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust, pulleys, no cat
13.6  @102             89         GIJoe      no cats, TBswitch, no smog, hypertech, 160stat,
13.67 @104 2.20        91 M6 3.45 Yorcci     stock mufflers, street tires. K&N air filter with open lid, EGR removed, A.I.R. pump gutted, frisbee removed, throttle body coolant bypass, dual exhaust without precats
13.70 @101 2.06 +1235' 94 A4      Drug Deliv stock
13.70 @104 2.05 +1000' 95 M6 3.45 SHINOBI-X  B&M shifter, Xpipe, elims
13.75 @ 99 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback
13.76 @102 2.10        86 M4 3.07 PaulRugger LTs, an SR a K+N and underdrive pulleys.
13.78 @101 1.99  +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back, K&N+lid
13.79 @100 2.00 +1000' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back
13.86 @ 99 2.11 +7000' 92 M6 3.45 TOM400CFI  Stock
13.87 @104 2.15        92 M6 3.45 FalsusNomen airbox lid
13.87 @ 97 1.95        87 A4      CRV3TT3    catback
13.89 @ 99 1.97    90F 86 A4      JrRifleCoa MSD, catback, Alvin chip
13.90 @ 98 1.97  +600' 87 A4 3.07 87 rag     1.6rollertips, Borla catback
13.90 @ 99 2.0         90 M6 3.45 MATCHLIGHT catback, fan switch, 180stat
13.91 @102 2.24 +1500' 88 M4 3.07 88espo     327ci, 461 heads
13.91 @ 99 2.11 +2445' 91 M6      neat       Hooker LTs, catback
13.92 @ 98 2.01        88 A4 3.07 popkid     Stock L98 with Pypes Dual Exhaust with x-over, no Cats
13.93 @ 99 2.07        85 M4 3.07 rel3rd     pulleys, hiflow cat
13.93 @ 98 1.93  104F  85 A4 3.73 krenalor   Ram air, stock motor, B&M TH700R4, TPIs cat back, Flowmasters, MT Sportsman tires
13.96 @ 99 2.01  +950' 89 M6 3.33 Z51L9889   stock
13.98 @ 99 1.86        86 A4 2.59 zbo2       bone stock, street tires
13.98 @ 97 1.99        87 A4      RS69       K&N, modified cats, ultaflow mufflers
14.02 @105 2.30        96 M6 3.45 ALLT4      bone stock LT4
14.04 @ 99 1.96        93 A4 2.59 MFS        2400 stall
14.09 @ 98 2.11        88 A4 3.07 popkid     stock, street tires, Pypes exhaust system
14.13 @ 98 1.99        85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust
14.14 @ 95 1.93        85 A4      rickhiggin bone stock
14.16 @ 93 1.88  1709' 87 A4 2.73 Lemme      T Headers, Shaved Heads, Stg 2 shift kit, 2600 TC, A/BOX Lid, power pipe, TB Bypass, airfoil, MAF gauze removed, K&N, AIR delete, precats delete, EGR delete, custom 89 ARAP bin
14.27 @ 99             85 A4 3.07 L98/Z51 L98 TPI ADS Stage 1 Super Chip, K&N Filter, airfoil, removed screen
14.33 @ 97 2.13        86         Agent 86   no cats, no smog, magnaflow exhaust
14.36 @ 98 2.27        85 M6 3.01 dclafleur  bone stock
14.44 @ 97 2.18        87 M4      Mr. Dude   lowered, bilstein shocks, borla high flow mufflers with true dual straight pipes, newer control arms, newer bushings, newer tie rods, K&N filter
14.46 @ 94 2.16        91 A4 2.59 1991 C4    B&B exhaust
14.47 @ 94 2.03 +2710' 89 A4 3.07 cuisinartv catback
14.63 @ 95 2.16        86 A4 3.07 KnightVett catback, K&N, (stock 86L heads)
14.7  @ 92             84 A4 3.07 xrcrx      cai, RRs
1/8 MILE
Code:
6.02 @111 1.28        90 A2 4.56 hookedup   420, carbed, PG
6.40 @105 1.39        84 A4 ???? vetjack    406 sbc on 175 shot
6.45 @116 1.54        92 M6 3.73 97AGGIE    383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh
6.52 @131 1.41        85 A4 3.07 CORKVETTE1 434ci, 11.5:1, solid roller, 4200 TC, single plane, monoblade TB, brodix t1 heads
6.64 @107 1.37        89 A3 3.73 ski_dwn_it M/T slicks, 434ci 11.5:1 compression, m2race system brodix t1 227cc heads, Single plane intake, 30# injectors, 3" exhaust, m/t front runners, turbo350 auto, 8" race converter
6.68 @105 1.47 +7000' 91 M6 3.70 tpi421vett 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9"
6.73 @104 1.51        91 M6 3.70 tpi421vett 421 bowtie block, ported miniram2, AFR220s, NOS, comp mech roller cam, F.A.S.T., monoblade
6.79 @102 1.55        83 A4 3.54 dan0617    383, 12.2 compression, 230/236 cam, AFR195's, HSR intake, 200 shot, 2800 stall, built 700R4, ET Street radials
6.82 @103             96 M6 4.10 d48mclain  398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake
6.91 @ 98 1.49        96 A4 3.75 RichS      396ci, DRs, morgantini heads, ported LT4 heads/int, 3600 TC, CompCam, DRM LTs, 58mm tb
6.99      1.53        85    3.45  IHRA221    383 spool
7.01 @108 1.82 +1200' 90 M6 3.91 mos90      396 solid roller, slicks, 250shot, mcleod clutch, FAST xfi
7.10 @ 98 1.60        96 M6 3.75 RichS      DRs, 396ci, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb, 421hp/412tq
7.22 @ 92 1.52        85 A4 4.10 85C4sX2    TFS 195 heads, TPIS MINI RAM, 58mm Throtle Body; TPIS ZZ9X HYD ROLLER CAM; ROSSLER 700 R4; 4000 stall TPIS HEADERS & CAT BACK SYSTEM; MT ET STREETS
7.24 @ 93 1.58        86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust
7.30 @ 97 1.69        92 A4 3.73 qwiketz    383 with vortech t trim, auto, Stock converter
7.30 @ 91 1.54   -90' 92 A4 3.33 MTVette    383 LT1, ported heads & intake, LT's, 2600 TC, DR's
7.31 @ 94 1.55        93 A4 3.73 93lt1fun   396 stroker LT1, GM 846Cam, ported LT1 heads, 52mm throttle body, Meziere water pump, TPiS LT headers, RT cats, 3500 stall Vig TC, MT ET Street DR's7.44 @ 93 1.76 +1600' 93         steve40th  425 rwhp 417 ft/lbs tq
7.35 @ 98 1.66  -500' 91 M6 3.90 neat       383, AFR heads, 230/236 cam, miniram, Mseven tune, nitto DRs, NA
7.38 @ 93 1.71        91 A4 3.45 twin540    383 stroker afr 195 eliminator, LT1 intake conversion 503 cam built tranny with 5 pinion planetary front/ back. 3.45 dana 44 9.5" 3000 stall converter on 315 mt et drag radials
7.49 @ 88 1.56   983' 93 A4 3.73 1989TTATony 383 LT1, 2800 TC, MT DRs, 1.6RR, Corsa cat-back, PCM4less tune, LE2 ported heads, custom cam
7.52 @ 92 1.67        86 A4 3.07 jd_v3tt3   150shot, BFG DRs, LTs, elims
7.53 @ 92 1.69        93 A4 4.09 93 ragtop  M/T et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune
7.55 @ 94 1.78        86 TKO     ol,RJ      406ci solid roller, victor E intake, brodix heads, 246/.542cam, LTs, tune, Toyo RA1
7.58 @ 91 1.68        95 A4 3.73 ckp        D36,3000 TC, 30lb Ford racing injectors, Bottom feeder air induction, Pro Flow XT intake, Wilson 90mm TB, Headers, Stock mufflers, skinnies and cheater slicks
7.67 @ 88 1.67        93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune
7.70 @ 87 1.62    80F 86 A4 2.73 vetster86  Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs
7.72 @ 89 1.7         84 A4 3.73 calpbs     383 carb, cam, dart pro 1's,11:1 compression, lightened rotating assembly, 3600 stall, 700r4, a-mod 315-35-17's, Street tires
7.76 @    1.78        96 M6 4.10 jonecap    DRs, EM LTs, R/T cats, catback, tune
7.78 @ 87 1.69        83' A4 3.73 reoch999   CC503 cam, 1.6RR, Flowmasters, 3000TC
7.79 @ 88 1.65  -460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels
7.80 @ 89 1.72   55F  96 A4 3.73 vettestir1 LT4 hot cam, mez ewp, 2800 stall, 52mm tb, cai, DR's and a few minor bolt on's
7.82 @ 89 1.74        96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's
7.82 @ 88 1.77        94 A4 3.45 blue94     AI ported Heads, 565 lift 110 LSA, 2800 Stall, LTs, MT ET's, D44
7.83 @ 92 1.94        90 M6 3.73 adi4       383, miniram, 224/234 cam, 1.52 RRs, trickflow 195s, 54mm TB, EM LTs, RT cats, Corsa, alum fw, MSD
7.85 @ 89 1.76        96 M6 4.10 jonecap    DRs, catback, tune
7.88 @ 88 1.78        96 M6 4.09 Dr. Evil   hotcam, alvin tune, LTs, catback
7.88 @ 89 1.80        93 A4 3.54 fredk      190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune
7.89 @ 88 1.75        96 A4 3.45 Weav's Vet LT1 226/230 .565.565, 111lsa Bullet cam, 1.6 Comp Cams full rollers, stock heads, 30lb FMS injectors, Cloyes DR timing chain, 52mm BBk throttle body, Dana 44, 2800 stall, ZFDoc's beam plates, K&N, 160 stat, EWP, M/T ET Street DR's
7.91 @ 85 1.68  +800' 92 A4 3.33 MTVette    M/T DRs, 2600 TC, LTs, hotcam, chip, 1.6RRs, RT cats, Xpipe
7.92 @ 85 1.63        91 A4 3.33 TA         stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs
7.94 @ 89 1.87     0' 91 M6 4.09 neat       100shot, ET streets, Hooker LTs, catback
7.95 @ 90 1.82     0' 90 M6 3.33 bogor      vortech s/c 8psi, ET streets superram, mild cam, LTs, 52mm TB, Autotronic SMC
7.96 @ 91 1.93        86 TKO     ol,RJ      406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune
7.97 @ 89 1.70        85 A4 3.73 rssshen ve roller 383, dart pro1 heads, 270 cam, Alvin chip, edelbrock base, SLP runners, 58mmTB, MSD, TPIs LTs, flows, 2800 TC, shift kit, BFG DRs
8.08 @ 86 1.83   100F 90         skateparkd M/T DRs, LTs, Monzas, Catless, 125shot, Jet stg 2 chip, 160stat, Fan Switch, frisbee
8.09 @ 90 1.87     0' 96    3.91 ericcer    LT4 motor/hotcam, LT headers, catless, custom tune, elec wpump, delteq ign
8.10 @ 85 1.86        89 A4      Chance     383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals
8.15 @ 83 1.80        87 A4 3.54 stauger    383 LPE
8.16 @ 84 1.78        85 A4 3.73 rssshen ve roller 383, dart pro1 heads, 270 cam, edelbrock base, 58mmTB, MSD, TPIs LTs, flows, 2600 TC, BFG DRs
8.20 @ 85 1.74  1702' 93 A4 3.07 1989TTATony 2800 TC, MT ET Streets, 1.5RR, Corsa cat-back, PCM4less tune, K&N w/cut air lid
8.23 @ 84 1.90        89 M6 3.33 Razor89    nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip
8.26 @ 82 1.77        86 A4 3.07 jd_v3tt3   BFG DRs, LTs, elims, stock iron heads
8.26 @ 83 1.78    68F 87 A4 3.07 rodj       M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB
8.29 @ 87 1.90        96 M6 4.09 Dr. Evil   hotcam, catback, K&N+cutlid
8.31 @ 91 2.04   107F 90 A4 3.45 conv90     383, trickflow heads, SuperRam, 219cam, LTs, 58mmTB
8.32 @ 86 1.90        87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs
8.34      2.01        96 A4      Legion21   SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI
8.38 @ 85 1.93        96 M6      ubnpast    DRs, SLP intake, flowmasters
8.39 @ 83 1.84  -100' 94 A4 3.07 Red98C5    DRs, cai
8.39      1.79  +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC
8.40 @ 84 1.95  -500' 95 M6 3.45 Mr Mojo    no mufflers
8.40 @ 86 1.99        89 M6 3.54 89sleeper  M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom
8.41 @ 85 1.95        94 M6      pr1mu5     DRs, centerforce clutch, no muffs
8.41 @ 84 1.97        94 M6 3.45 1stvette94 DRs, 1.6RRs, meziere
8.42 @ 83 1.96        91 M6 4.10 neat       LTs, catback, 1.6RRs, tune
8.43 @ 84 1.96        92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip
8.43 @ 83 1.91        90 M6      jonecap    TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys
8.45 @ 87 2.20        87 A4 2.59 CRV3TT3    Paxton S/C, exh, M/T DRs
8.45 @ 83 1.91        89 M6 3.33 Z51L9889   ported 113s, no precats, cat&back, portedTPI
8.46 @ 81 1.82        85         black85    LTs, catback, pulleys, ported TPI
8.46 @ 85 2.04        89    3.07 kopbet89c4 miniram, no cats, chip, 24# inj, no MAF
8.46 @ 85 1.97        89 M6 3.33 black_89_v 383, superram, LTs
8.46 @ 80 1.77        90 A4 3.07 Crowhater  zz4 crate, Lingenfelter headers, NX nitrous, 2800 stall, Kumho's
8.47 @ 84 2.04        87 A4 2.73 slverdrptp Stock 113 heads, TPIS ZZ9 cam, TPIS Big Mouth intake, AS&M semi-siamised runners, Comp Cams 1.5 Pro Magnum roller rockers, SVO 24lb flow matched injectors, true dual 2 1/2" exhaust off factory headers with Flowmaster mufflers, chip by skidownit
8.48 @ 82 1.99  -400' 88 A4 2.59 65Z01      SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs
8.49 @ 83 2.07 -2150' 95 M6 3.45 Mr Mojo    none
8.50 @ 83 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties
8.51 @ 85 1.95        96 M6      Jack_lt4   flowmaster
8.53 @ 88 2.17        85 M6 3.45 LD85       406ci, AFR 210s, Miniram
8.53 @ 86 1.97  60F   94 M6 3.45 chevy406   LTs, cai, no cats, centerforce DF, 1.6RRs
8.54 @85 1.95   2771' 92 A4 2.59 04gtogoat  hotcam, 1.6RR, CC full exhaust catless, eliminators, power coupler, MSD blaster, 30LB injectors
8.57 @ 85 2.06  +500' 93 M6 3.45 mn_vette   iron heads, no cats, mez wp, 58mmTB, 230/236 cam
8.57 @ 84 1.94   60F  95 A4 3.07 pettvette
8.59 @ 86 1.90   50F  95 A4 3.07 aminnich   DRs and elims, Meziere WP, otherwise bone stock
8.64 @ 84 2.12        94 M6      1stvette94 stock
8.64 @ 79 1.86  -400' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back
8.64 @ 81 1.94        92 A4 3.54 mcnulty95  shift kit, elims
8.65 @ 81 1.99  -500' 88         65Z01
8.68 @ 83 2.11        95 M6 3.45 Jonnymac   SLP cai, 1.6 RR, Borla catback
8.69 @ 81 1.95        93    4.10 Driftmonst LTs, chip, borla exh
8.71 @ 84 2.04        89    3.07 kopbet89c4 Superram, no cats/smog, Alvin chip, 24# inj
8.71 @ 79 1.89        88 A4      hooblyboob miniram, 2500 TC, ported heads, cam
8.71 @ 82 2.21 -2150' 95 M6 3.45 Mr Mojo    stock
8.73 @ 83 2.21 -2150' 94 M6 3.92 DaveT      just gears
8.74 @ 80 2.09        85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust, pulleys, no cat
8.76 @ 82 2.05        96 A4 3.07 Gmans96Cou Vortex ram air, 52mm TB, Borlas, no cats, granatelli MAF
8.79 @ 79 1.88        86 A4 2.59 Corv Chris Dynomax Catback, Flow Kooler W/P, TB Bypass, TB Airfoil, 180 'stat, K&N Filters, Bosch Design III Injectors
8.82 @ 78 1.97  +600' 87 A4 3.07 87 rag     1.6rollertips, Borla catback
8.84 @ 79 1.99  +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back
8.84 @ 79 2.06 +1235' 94 A4      Drug Deliv stock
8.8  @ 81 2.2         92 A4 3.45 MrNuke     chip, Borlas
8.83 @ 79 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback
8.84 @ 77 1.89        86 A4 2.59 Corv Chris K&N, muffs, (stock 86L heads)
8.85 @ 78 1.95        87 A4      CRV3TT3    catback
8.85 @ 76 1.86        86 A4 2.59 zbo2       bone stock, street tires
8.91 @ 80 2.09  -200' 85 M6 3.07 CentralCoa SLP cai, elims, cat&back
8.91 @    1.86        95 M6 3.45 95wht6spd  cut lid + K&N
8.93 @ 83 2.24 +2445' 91 M6      neat       100shot, Hooker LTs, catback
8.94 @ 79 1.99        87 A4      RS69       K&N, modified cats, ultaflow mufflers
8.95 @ 78 2.11 +2445' 91 M6      neat       Hooker LTs, catback
8.95 @ 76 1.88  1709' 87 A4 2.73 Lemme      T Headers, Shaved Heads, Stg 2 shift kit, 2600 TC, A/BOX Lid, power pipe, TB Bypass, airfoil, MAF gauze removed, K&N, AIR delete, precats delete, EGR delete, custom 89 ARAP bin
8.96 @ 78 2.07        85 M4 3.07 rel3rd     pulleys, hiflow cat
8.96 @ 76 1.93        85 A4      rickhiggin bone stock
9.09 @ 78 2.06  +500' 85 M4 3.07 CentralCoa SLP cai, elims, cat&back
9.10 @ 82 2.24 +1500' 88 M4 3.07 88espo     327ci, 461 heads
9.23 @ 76 2.13        86         Agent 86   no cat, no smog, magnaflow exhaust
9.24 @ 74 2.03 +2710' 89 A4 3.07 cuisinartv catback
9.15 @ 77 2.21        88 A4 3.07 popkid     stock, street tires, no mufflers
9.32 @ 76 2.16        91 A4 2.59 1991 C4    B&B exhaust
9.35 @ 78 2.09        88 A4 2.73 gbody5     stock
9.39 @ 80 2.18        87 M4      Mr. Dude   lowered, bilstein shocks, borla high flow mufflers with true dual straight pipes, newer control arms, newer bushings, newer tie rods, K&N filter
CAI: cold air intake
DRs: drag radials
elims: muffler eliminators
LTs: long tube headers
RRs: roller rockers
SR: SuperRam intake
TC: torque converter
Last edited by MTVette; 08-22-2011 at 01:34 PM. Reason: Added Crowhater and 04gtogoat; updated Aardwolf
Old 10-13-2008, 12:43 PM
AKS Racing
AKS Racing's Avatar
I didn't notice many FI cars, so I will add mine. Time slip is from early spring, and temp in the low 70s.
9.34 @ 152.7, 1.82 60'. I have slightly better 60' times with this combo (some in the 1.7s), and a few with a couple more MPH (crappy 60' and spinning adds speed), but this slip is probably the best overall.
'87, 408cid (4" stroke, 350 block), AFR215s, 248/254 @ 0.050 SR cam, SP intake, MB, D1R, FAST sequential, ZF, 3.45D44
Old 10-13-2008, 12:46 PM
dclafleur
dclafleur's Avatar
Noticed my run wasn't up here, this was when I was bone stock earlier this year.
My best run was
R/T .618
60' 2.274
1/8 9.300
1/8 MPH 77.63
1/4 14.367
MPH 97.69
'85 4+3 with 3.07's
Last edited by dclafleur; 10-13-2008 at 12:49 PM. Reason: forgot year and transmission
Old 10-13-2008, 02:30 PM
C4DC
C4DC's Avatar
St. Jude Donor '06
See sig
Old 10-13-2008, 03:41 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
What was wrong with the other thread?
Old 10-13-2008, 04:06 PM
MTVette
MTVette's Avatar
CentralCoaster moved to band camp and stayed there.
Old 10-13-2008, 04:11 PM
cv67
cv67's Avatar
St. Jude Donor '05
Was it locked recently or back then? Just curious
Old 10-13-2008, 04:30 PM
MTVette
MTVette's Avatar
Updated 10/13/08
Old 10-13-2008, 04:31 PM
MTVette
MTVette's Avatar
Today, at my request, so members would know to post new bests to this thread.
Old 10-13-2008, 04:34 PM
tpi 421 vette
tpi 421 vette's Avatar
Here is a update for mine. 10.36@135.86 1.52/60. DA 6800 ft. 450ci AFR220's, Miniram, Crane 252/260 solid roller, FAST, 200 shot NOS, ZF6, 3.70 9".
6.68@105 1/8mile 1.47/60 DA7000 ft
Old 10-13-2008, 04:42 PM
_twisted_
_twisted_'s Avatar
my newest best is in my sig, thanks for taking over the list - you will surely get hit with a bunch now that cooler air is coming
Old 10-13-2008, 05:50 PM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
Here's mine. 13.76@101.7 with a 2.1 60. Its a cast iron head 86 with LTs, an SR a K+N and underdrive pulleys. Its a 4+3 with a 3.07s and the drivetrain is stock except a Fidanza aluminun flywheel. I'm in the process of installing aluminun heads off a 90 and 1.6 roller rockers.
Old 10-13-2008, 06:09 PM
cv67
cv67's Avatar
St. Jude Donor '05
Can I put this in my sig?
Old 10-13-2008, 08:24 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
And as long as it stays on track it stays open
Old 10-13-2008, 08:27 PM
Corvette Chris
Corvette Chris's Avatar
I haven't been able to beat that 8.84 time. Gonna have to dig out the checkbook me thinks.
Old 10-13-2008, 09:00 PM
qwiketz
qwiketz's Avatar
here's mine. 1/8 mile, 7.30 @ 97 on a 1.69 60'. 383 with vortech t trim, auto, 3.73 gears. Stock converter, off idle at 900 rpm. No quarter runs.
Old 10-16-2008, 12:25 AM
Eddie & the Cruisers
Eddie & the Cruisers's Avatar
Would be nice if you could make the column headers stationary so when you have to scroll vertical and/ or horizontal, you don't have to remember what each column is. And when there are page breaks, repeat column headers on the next page.
Another column for Coupe or Convertible would be good since there is about 200# difference in the two.
To The NEW Official Timeslip Thread
Old 10-16-2008, 10:35 PM
tensecvet
tensecvet's Avatar
8.3 @169 - 1.30 60ft
Carrolls Rod & Racecraft Bolt-in rear, glide, some rims and ahh "No power" Bammann 565 motor & 350 shot
Old 10-16-2008, 11:51 PM
MTVette
MTVette's Avatar
I'm gonna need more info before I can add that one. Year of car, tranny, gearing...
Old 10-16-2008, 11:53 PM
zbo2
zbo2's Avatar
my best with my 11,000 mile bone stock, street tired, aluminum headed, automatic 86 coupe.
R/T .641
60' 1.867
330' 5.658
1/8 8.856
MPH 76.36
990' 11.562
1/4 13.986
MPH 94.91
Quick Reply: The NEW Official Timeslip Thread
