Aluminum radiator is it worth the money?
i am going to replace my radiator soon and saw a advertisement for aluminum radiators but they cost about 3 times the price for a oem radiator, my question: are aluminum radiators worth the extra money?
what do they provide over a oem radiator that justify the extra cost?
thanks boonie
thanks boonie
If your car is stock or mildly modified, the OEM radiator will do just fine.
I got a brand new OEM radiator from www.corvetterecycling.com for $135 shipped to my door.
I track mine with the old stocker and have not been able to get it very hot, 195° has been max so far. If you were happy with the temp before then use another stocker. BTW why do you want to replace it?
thanks boonie
thanks boonie
Part of the question should include whether you need/want a cooler running motor. CFI-EFI pointed out that a hot motor is an efficient/powerful motor. He said... just as you want to have cooler air going in the motor (for expansion of air molecules), you want to have it get as hot as possible (for the same reason). This was something I'd never thought of. I, as many others, assumed that cooling adds longevity w/o any consideration for operation. I believe he added that hotter motors can burn cleaner. (I'm not the expert on this, but what he said made sense.)
If lowering running temp is your goal, coordination of thermostat/fan/radiator/water pump/ECM should be considered. Changing at least two of these is often required to lower temps.
Yes
All I can say is, I got a Dewitts and it works great. Too great. I had major run hot problems. Put in and runs right at thermostat, 180 degrees. To me it was worth it
Random tech: the digital readout will say HOT OIL when the temp goes over 305.
On the highway it would be 200 - 210. On the track after 20 min > 230
With the Dewitts will occasionaly see 230, but the fans will come on and it will drop. Highway it rarely goes over 190 (same temp as thermostat). On the track after 20 min around 210.
I love my Dewitts!!!!
I've heard Tom's radiators are a work of art!
Personally, I couldn't afford one though. I ended up with one of these. Seems to work just fine for my needs.
http://www.radiatorsus.com/servlet/t...NEW-ALL/Detail
