Steering wheel vibration, causd by bent rim??
Hey guys. Had my car checkd out today and the mech. said it's the rims causing the problem. Said they are bent. Which they are that. Funny thing is the rims are no different now then they were 4 years ago. I didn't notice this vibration unitl I got the new tires, and it did vibrate a few times. Then stopped, now it's all the time. Started when it got could out. Could this had an effect on the metal of the rim? I'm guessing they may have bent the rims some putting the tires on? So, I guess what I am wondering is why would they start to vib now. Why didn't they do it 4 years ago? Engineers can you help?
Re: Steering wheel vibration, causd by bent rim?? (88_vette)
What indication do you have that they are bent? The factory rims are not bendable. They will crack before bending because the cast magnesium they are made of is very brittle and very stiff. I know mine would not bend...right up to the point I cracked one of them.
Every time I have sen this vibration happen, it's been the tires. Certain brands are just crap, and thats all there is to it. That doesn't mean they wont handle well...but....
Re: Steering wheel vibration, causd by bent rim?? (BBA)
Thanks BBA,
I pick it up tomorrow. The mech said tires to star with until he looked at it. The tires are new, but they are cheap ones. The rims are alum. I know they are bent because you can see it. One is pretty bad, but it's been this way for 4 years. Which is why I'm puzzled about it messing things up now? I new rims anyway, so I guess I'll buy some.
Very likely.
I was in a torrential rainstorm back when I first got mine,and ran over a good sized piece of wood. Nothing else got Hurt...but the hour long drive(after I checked the rim to insure everything was ok) was a rough one. Lemme see if this works. :lol: I drove around for six months with this thing on there.
Your vibration should go away once you repair/replace the rim.
JD
JD
Re: Steering wheel vibration, causd by bent rim?? (JD 90 383)
I spun out and nailed a curb and bent both right side rims on the (i dont know what you call it) part that comes in contact with the tire. I couldn't go over 55 without very violent shaking. They weren't even bent that much...
Re: Steering wheel vibration, causd by bent rim?? (JoeVette88)
Check and see if they are just not balanced. It happened to me before, steering wheel shook when they weren't balanced. No more shake after that.
Before replacing rim, I would sure take it to a good tire shop and check the balance and maybe even check to make sure tire was mounted correctly, won't cost that much and could save a bunch--My 84 had a vibration at high speed and I just knew it was something bad-- Checked the balance and had both right sides out about a 1 1/2 ounce each -- $36 for all 4 rebalanced. ;)
Smooth as glass now--If its bent You will be able to see it --while balancing
[Modified by Flasher, 9:38 PM 1/15/2002]
Had the same problem with some 99 rims. Checked everything first then ended up replacing the rims. No more vibration problems.
Rims are not as hard to bend as most people think, especially 88-89. The 88-89 rims are two piece, aluminum and steel. The rims do go out of round from heat from the road, brakes, etc. then hitting a relatively small bump, pothole, etc.
There is a place here in Georgia that can fix bent rims,curb rashes etc.The name is The Wheel Wizzard.I have a rear wheel that has a side to side wobble,and they quoted me $140.00 to straighten and repair.I have a friend that bent a rim on his lowered truck and they fixed it like new.If you can't find the number I will get it for you.
Re: Steering wheel vibration, causd by bent rim?? (bogus)
vette rims are aluminum... not mag...
Ummm...Ok, I'll give you that maybe the 88 and newer are, but the 16" 87 and older ones are in fact magnesium...and I have the powdery chunks of one of my wheels to prove it.
Although this turned out not to be wheel related,, you might want to check your tie rod ends. I was having a vibration between 70 and 75 mph and couldn`t figure it out until last weekend when I was washing the grime off the front end. When I grabed the wheel and rocked it I could see play in the right tie rod end. So tonight I replaced them both. Took the car out and ran it hard up past 90 mph and was steady as a rock. Might be worth a look in your case. :flag :cheers:
