Broke coolant hardline - where to buy?
'91 L98, was setting the timing to 6*BTDC (went well BTW) and noticed a new leak while adding water through the reservoir cap. It turns out the hard-line that transfers coolant from the top of the expansion tank to the reservoir broke. The rubber hose is crimped to the hard-line and I don't have the tools to fab new lines.
I checked all the normal vendors and nobody sells it. So I'm guessing I'll look for a radiator shop tomorrow? Will they bend it for me if I bring the old one in? Or do I just have them crimp it and buy a cheap Harbor Freight tubing bender and DIY?
This is the tube I'm looking for:
Cracked:
Thanks and I hope everyone enjoyed the holidays,
Jonathan
Cracked:
Jonathan
I would buy a flare tool and a piece of hard line. After that you can just bend it to shape and hold it down with a hose clamp. You'll be in it for about $20 and have the tools. Use a compression type flare, not the bell end as these will cut the rubber line.
Where can I buy the hard-line? I don't think I've seen any at the local auto part stores. I do have a flare tool already and know where to buy compression fittings though.
Ideally, I would get an old piece, but the closest corvette salvage yard that I've used before is about an hour away and I don't feel like driving that far today.
Thanks to all,
Jonathan
