Dewitt's Radiator Instructions Doesn't Seem Right
Did I miss something or did I just cut up my '94's radiator shroud for no good reason? I cut the shroud 3/4 of an inch like the instructions below say and now I have this gap between the radiator and the shroud. It looks like it would have been perfect if I didn't cut it. Can someone help me out, it seems straight forward but I must have missed something.
Here is what it looks like now:
Here are the instructions:
There's no way the radiator can move anywhere, look at the sides of it, the shroud touching the sides of the radiator stick out about a 1/2 inch past where the gap is. The fan assembly is in there.
Here are more pics.
This is where the part of the shroud touches the side of the radiator so it can't move forward anymore even if the upper shroud is in place.
These show the fan assembly is in.
Another look at the part of the shroud that is keeping the radiator from moving forward.
What I am refering to, is on mine when the fan assembly is unbolted from the back of the shroud, it will lean back towards the motor. W/out the upper shroud in the rad also doesn't exactly sit right. I can't tell in the pics, but are you also saying it is to tight to the left and right in the lower part of the shroud, so that it cannot move at all?
Ok here are some better pics that clearly show the part of the shroud I am talking about that is preventing the radiator from moving back to close the gap. I am pointing to it with that green thing in the first pic.
Those are better pics. and now I can see what you mean, it doesn't look like you missed anything. The outside edge of the fan ***. was the same as the inside "shadded areas". At this point, the only thing I would be looking at is if the outside edges of the fan ***. will prevent it from bolting the the top shroud w/out shimming.
From what you've mentioned, I am wondering if the outside edges on both sides will need to be trimmed as well. If so, at least that would allow those "shaded areas" to get up tighter to the rad. Either way, I wouldn't get a new shroud I don't think the cutting will hurt it, based on the thicker core.
tom's place is about 20minutes from my house and when mine was done I went and picked it up. While I had some extra things/mods done to this one, I did a lot of measuring prior and questioned John about the other issues w/the aftermarket rad., and this part was not addressed. But post back with the verdict. I have one sitting here that I need to put in, been a little lazy in the last couple of weeks......guess I'll fire up the heater today and get my butt out there....it's about 20*f outside.
Mine's the same (1992). I kept the part of the shroud that was cut off and next time I feel compelled to access the radiator area I intend to re-attach the removed part... In terms of everyday driving, the shroud only makes a difference at lower speeds; I have operated mine for 2 full summers in Atlanta with the 'shroud gap' and it works just fine. Actually, one thing you should check before you put the covers back on is the gap under the radiator - on mine I had a large gap that I had to fill post-installation. IMO that makes more of a difference to cooling efficiency than the gap inside the shroud.
The verdict isn't good. The sides of the shroud can't be trimmed back enough to compensate for the gap because on the driver side of the shroud there is a section of plastic about 2 inches wide that goes the height of the shroud which prevents cutting that part of the shroud any further. Actually the part of the shroud that the directions say to cut back actually need to stick out FURTHER than the sides because the middle part of the radiator is recessed about 1/4 of an inch compared to the sides. The directions are completely opposite of what needed to be done. I guess other years must be different but the directions are just plain wrong for my car. It's time to search eBay or call up Vette2Vette for a new shroud. I know the gap won't make the car blow up or anything but it bothers me knowing it's not right
I don't want to have to shim it out this way, hhhhmmmm
Yeah I got those in too with my radiator, but from what Tom said in a thread on here its better to have the radiator closer to the fans so it will cool better than shimming it back. I don't see why I would call them though, the shroud is already ruined.
