what is this engine? suffix code UKA
the suffix code on the place where they stamp the serial number is UKA. I have looked and only reference of this suffix is a 1981 350. However this is a TPI engine another thing is why isn't my VIN number stamped on the pad either?
By the way this is in my 1990 vette the suffix might even be VKA but I never came across a VKA searching.
I did another thread on this car I took the motor apart because of a suspected blown head gasket. However after pulling valve covers looked like a much lower mileage engine then the stated 189k on odometer. so I cleaned the pad and find no vin number on it and just a few letters in front of this suffix code.
it has felpro head and intake gaskets so it had to have had work done on it before I bought it.
just though the suffix code and missing vin number odd and wondered if anyone has ever seen this before.
Engine code UTA
I just looked it up @ Chevy small block identification codes, then go to small block suffix codes: it is an '81 truck motor w/con. cab, m/t, 2 bbl, used in C-30's and 3500's, and A.I.R. (emission language to me).
But that's not a bad thing altogether because it is almost sure to be a 4 bolt main engine.
I've got one here from and 80 truck, and it is a four bolt. Hope this helps, and doesn't dash your hopes too much.
rk
BTW, there is no VTA, so the U is what it is, a U
OH, and the numbers are the date it was made, and the first letter is what plant it was cast in, such as Flint, MI.
You will see all of this at that site. Good luck.
rk
Last edited by thirdtimevetteowner; 02-23-2009 at 01:59 AM. Reason: forgot something
rk
rk
so that disproves it as being a 1981 engine.
There is a mistake in my original post. I typed UTA instead of UKA, but nevertheless, there are still NO VKA suffixes.
The first V = Flint MI. plant, the 0202 = second day, of the second month, and the UKA = as stated above, an 81 truck motor, probably a 4 bolt.
I stand corrected. You must be mistaking the U for a V, and even so, there are only four V suffixes on the chart, all of which are 305 motors.
I think I would prefer it to be a U. As far as it being a roller motor, are you saying Chevy style roller lifters, w/the stamped plate that keeps them from turning? Or is it a retro-fit roller, w/bars connecting adjacent lifters for each cylinder?
rk
rk
rk
rk
SGI
on othe other side of distributor its marked 14093638
I checked and the 14093638 comes up as a 87-95 350 2 or 4 bolt main 1 piece rear main seal .... at least its not a 305 was kinda worried about that LOL. Now I wonder if it has a L-98 profile cam in it.
