Specs on a 94 stock LT1
Cruise-In II Veteran
Re: Specs on a 94 stock LT1 (bwagner)
If it has 2.59 gears figure 13.9-13.7 at 101-104MPH.
With 3.07 rear end, figure same trap speeds with a 13.7-13.3.
These are what I have witnessed personally or raced against. Others may have a different view.
Re: Specs on a 94 stock LT1 (C4 4Me)
Thanks...that's about what I thought. I've done minor things to mine. K&N air filter, airfoil, performance exhaust system, and I'm thinking about punching the cats out. Plus I've opened to top of my air filter housing. So that the air filter is exposed. And I don't know how much this will do, but I'm doing plugs and wire change this weekend and went to MSD 8.5mm wires, with the normal AC Delco Platinum plugs....
Stock (with 2.59 gears), mine ran a 13.733 @ 101.781 mph and a 13.800 @ 102.288 mph. On the 13.73 run, I pulled a 2.023 60'. This was all bone stock (56,000 miles) and on street tires.
Re: Specs on a 94 stock LT1 (ZBRA)
Hey ZBRA,
Like the Admiral Blue, that's what I have, 94. I like your interior. Did you do that yourself? I've customized my interior somewhat. I've taken the air condition vents and have primed and painted them a torch red. I also did the center pieces, the panels that are around the display, and the panel that's around the gear shifter. It looks awesome. I'm going to continue on and get the torch red carpet and door panels as well, along with the seats.
Hey ZBRA,
Later :seeya
Try this website. I found alot of good stuff here. http://www.corvettearchive.com/
