Coolant Temperature Gauge Failure
I have a 1990 a4. The coolant temperature gauge on the dash stopped working. it is flat 0. The other gauges all work fine
I changed the coolant temperature sensor on the intake manifold and it still does not work.
Looking at the Haynes Manual 1 line diagram, it looks like there is something called an
"Engine Metal Temperature Switch" feeding the gauge.
Could this be the problem?? Where physically is this in/on the car??
I have a PCM for less chip in the car.
Help with this one appreciated.
Flatbush 862
Flatbush 862
Yes thanks Agent 86-
After researching a little bit I found the correct part and location. The auto parts stores often confuse the temperature coolant "sensor" with the coolant "sending unit" the sending unit is as you said on the passenger side head near the #6 cylinder plug. The sending unit has a blade connection where as the "sensor" is a socket connection at the front of the intake manifold under the Throttle body.
Flatbush 862
Flatbush 862
Flatbush 862
Flatbush 862
Hi there is a sensor on the passangers side of the car close to the back of the motor right next to the back spark plug ,,,That sersor controls the temp gauge the one on the mainifold is just a temp switch check that back senson there is 1 single wire that mounts to it some times that wire gets melted or just gets loose and falls off the ground prong and when the wire falls off the gauge will NO longer WORK as this happens to my 1990 c4 with the L98 motor in it when that wire falls off too it stops sending the temp of the motor to the ECM and turns the gauge off and some times sends a check gauge signal to the info centor on the dash Hope i helped some
Bogie dog (11-25-2015)
Temp. Gauge Failure
I just bought a 1990 Corvette and the Temp. gauge was not working all so . I all so looked at the sender at the front of the engine as that is were Chevy used to put the Temp sender . I would have never looked by the right rear spark plug . Sure enough there it was with the wire disconnected . I reconnected it and now the gauge work's fine . Thanks for the help .
1 Post
Similar thing is happening with my 92 LT1.
The gauge just randomly stopped working, BUT the digital coolant temp. readout still works.
Could it still be that part on the passenger firewall?
The " just a temp switch" is the coolant temp sensor (CTS ) located in the intake at front that sends engine temp to ECM and is a major item in engine control
Sending unit in head only runs the temp gauge
Nilak (12-14-2023)
The temperature sending unit in the right head is needed for the analog temperature gauge located in the dash to work . If it worked once and a while the wire connector was loose and now is disconnected . The sender is located next to a spark plug so when changing plugs it gets knocked off .
Nilak (12-14-2023)
The passenger side just in front of the spark plug closes the fire wall is where You will find the Temp. sender . The wire is green and it is a single connector . Have Fun !!!
Cliff - Post #14 is 30 months old and #15 is a very vague inquiry mentioning NOTHING about the car!
POSTER "Tony Velasquez" - What year is your car? It would likely be suggested by some that you post a NEW thread but since you're here mention more information about your car. Year, engine, transmission etc.
You mentioned "stock" - shouldn't be an issue!
Well its a 87 vette with the 5.7 tuned port engine. My temp gauge is going crazy , but whats so funny is i dont even have it conected i dis conected the one in front an the one on the side because i figured that since i disconnected the temp sending unit an that done nothing it still kept marking it goes from 250 to 299 but mainly stays on 299 can their be another one located some where else
temp guage
