1993 A/C control diagram
Old 04-27-2009, 10:18 PM
Ginny C6
Ginny C6's Avatar
CI 6-7-8-9-10-12 Veteran
St. Jude Donor '11
Default 1993 A/C control diagram
I got a friend who is troubleshooting the a/c on his '93 coupe. Would anyone have this diagram to help him? Thanks in advance, Kevin
Old 04-28-2009, 01:02 PM
SunCr
SunCr's Avatar
Better to post the specific problem so we can provide the relevant info.
Old 04-28-2009, 05:49 PM
Wildride
Wildride's Avatar
Cruise-In II Veteran
I agree with SunCr-what is the problem?
This could give him some ideas IF the controller is part of the problem:
http://www.batee.com/corvette/acrepa...oard/c68.shtml
Old 04-28-2009, 07:20 PM
RLG
RLG's Avatar
I just went through all of this on my 90,
I agree with the posts above.
I am sure someone here has had your friends specific problem.
Old 04-28-2009, 10:38 PM
Ginny C6
Ginny C6's Avatar
St. Jude Donor '11
I'll talk to him tomorrow and post. Thanks Kevin
Old 04-30-2009, 07:03 AM
Ginny C6
Ginny C6's Avatar
St. Jude Donor '11
His problem is the compressor will not come on even thought the low pressure switch is closed and there is a charge on the system. The compressor is not getting +12 volts. What he's looking for is the air conditioning control diagram showing ECU connections, compressor relay and pressure sensors. Kevin
Old 04-30-2009, 08:05 AM
Epimax
Epimax's Avatar
Hope this helps..
Didn't know if the climate control was automatic or manual, so I included some info for both
Old 04-30-2009, 09:55 AM
Ginny C6
Ginny C6's Avatar
St. Jude Donor '11
Thanks!
Old 04-30-2009, 10:18 AM
Epimax
Epimax's Avatar
Originally Posted by Ginny C6
Thanks!
You Bet!
Old 04-30-2009, 12:56 PM
SunCr
SunCr's Avatar
Any a/c trouble code will kill it - make sure there are none by disconnecting and reconnecting the battery first. That way, you don't replace good parts.
Old 04-30-2009, 04:18 PM
RLG
RLG's Avatar
on my 90 I had the same issue. My head unit worked but the A/C clutch would not engage. If your head unit works go to the relay and see if you have 12 to both wires when the A/C is on, ground the small brown one , if it turns on the clutch it's probably the ECM unit. The ECM unit grounds that wire to engage the clutch. If your not getting 12 volts to both relay wires when the A/C is turned on it's probably the relay. On mine it was the green wire that goes to the pressure switch. it had been cut. The above info was at the courtesy of toptech and twisterup. If they jump in, follow their lead.
Old 04-30-2009, 11:06 PM
SunCr
SunCr's Avatar
Your '90 had somewhat different problem with an open in the Low Pressure Switch wiring, though if this '93 had a loose or intermittent connection at the switch (common on the '94), it would cause the same condition. Otherwise, if the contacts are closed, the connection is good, and the system has gas - the reasons the Relay won't drive the compressor clutch are: a stored trouble code (most common) - a bad relay - a bad control panel or programmer (Electronic Air) - or a bad ECM - or bad CCM (Electronic Air - though that is really rare since the link is for diagnostics) - or a defective Pressure Sensor (on some GM's it will trigger a PCM code). Also, the second schematic is for Manual Air - Electronic is a bit different with the Programmer sending the a/c request to the PCM and there should be another schematic for it - there's only the Control panel to Programmer shown in the Electronic Air schematic.
Old 05-01-2009, 05:01 PM
RLG
RLG's Avatar
I didn't have any codes, so basically I chased 12 volts around until I got to the last point where it would no longer read 12 volts. Then I ran a test jumper from the green wire to the switch and the compressor worked.
once I determined I had 12 volts past the ECM I was pretty sure that was the only thing left.
Old 08-11-2020, 12:39 AM
A_S
A_S's Avatar
On my 93 C4 can't find A/C relay under Instrument panel. Any idea where it could be hidden?
From clutch dark green wire goes to green ecm conn pin1. Can't trace circuit to relay....
Thank you in advance
Old 08-11-2020, 11:13 AM
RLG
RLG's Avatar
Kevin. If I remember right it's behind the knee bolster on the right side. There are several relays on the panel.
Old 08-11-2020, 08:02 PM
A_S
A_S's Avatar
Hi to all,
Finally found a/c relay under coolant expansion tank. Look all original wiring.
To 1993 A/C control diagram
Quick Reply: 1993 A/C control diagram
