Brake pads for 85 which ones?
Hi I have an 85 as well and the brakes on these cars are crap. I live in Norway an on my SAAB and sons Volvo the cars outbrake the Corvette many times. That said I hahve experimented much to increase the braking ability.
First I used Semimetallic and they were better but still not good. Then I went to Greenstuff by EBC and this was a big step forward but they had the ability to brake good at low speeds and they seemed to have problems at braking at higher speeds.
Then I was recommended to change the rotors to Powerslot and HAwk brake pads. I used the HAwk HPS and now the brakes are acceptable I hahve generally good brakes at all speeds and if braking much I get better performance as they heat up just opposite of my earlier pads including Greenstuff. The HPS by Hawk has not much brake dust and are silent. The HP plus pads are better as performance pads thogh and feels even better than HPS but can wear rotors more and can squeek.
I am sure there are many opinions about pads and rotors but this is my experience.
Good luck
Good luck
There are a wide variety of pads available for different types of driving. For general street use, there are some good ceramic pads that provide vey good braking characteristics and do not generate any brake dust. NAP has some good pads, Raybestos pads work well as do the Hawk ceramics.
IF you drive the car in a "spirited" manner then look at the Hawk HPS pad. This is a great pad for autocross and just when you want stop quickly. Another pad at this level is the EBC YellowStuff.
A few years ago, I tried a set of the EBC GreenStuff pads and while they worked for general street use, they sucked for had braking. I completely ruined a set for one track day which was 4 20 minute sessions. EBC is under new ownership and they have changed their pad materials and supposedly are much better than a few years ago.
For general street use, any good rotor will do. Drilled and slotted rotors are fine for appearance or "bling" but stay away from them if you intend to do serious brake work like track days. Use stock rotors for that.
A good semi-metallic pad should work fine and the Hawk HPS is available for the 85 in both front and rear. The HP+ pad is more of a track day/HPDE pad and work fine for that, but these pads do need some heat in them to work. They also generate tons of dust.
You didn't say what overall condition the brake system is in, but I would recommend a complete fluid flush along with new rotors. For street use, Castrol LMA is a good fluid and another is the Ford (yes, F*** ) MotorSports HD fluid. You will need just under a quart for a full flush. Either of these comes in small cans so you don't waste any extra in the quart size jugs.
If the flexible brake lines are more than 10 years old, get new ones; either stock or braided stainless steel lines. Old rubber lines will get soft and the interior hose part can expand as brake pressure rises and actually cuts braking performance.
