So My car failed Emissions...
Old 05-14-2009, 08:39 PM
RandyJ75
RandyJ75's Avatar
St. Jude Donor '06-'07
Default So My car failed Emissions...
My car (1990 L98) recently failed it's emission test for high NOx. The is basically stock w/ 24lb injectors, true dual exhaust w/ cats, and a custom chip to delete the EGR, which has been removed. The car has a recent tune up, w/ new plugs, wires, cap, fuel filter. It had it's intake removed and resealed using FelPro gaskets last April. Other then that, the car runs great, w/ no problems at all. Mileage is about 102K.
The strange thing to me is that it was well within the limits of the other two categories.
This what the test said;
hydrocarbons 1.4000gpm -0.4612 pass
carbon monoxide 30.0000gpm -5.1493 pass
oxides of nitrogen 2.5000gpm -2.8883 fail
Anyone have any ideas as to why it failed?
Thanks, Randy
Old 05-14-2009, 08:53 PM
farscape1a
farscape1a's Avatar
the high NOx may be because of the EGR delete... is that at all possible?
Old 05-14-2009, 08:55 PM
RandyJ75
RandyJ75's Avatar
Many people here have deleted the EGR and still pass emissions.
farscape1a
farscape1a's Avatar
okay...i was just curious...
Old 05-14-2009, 09:33 PM
jtc44
jtc44's Avatar
Default nox hi/
NOX hi caused by hi comb. temp. due to inop. egr or hot eng. lean cond. check comp. for cods. and eng temp, Good luck!!
Old 05-14-2009, 09:45 PM
CorvetteMike2024
Corvette Junkie
Support Corvetteforum!
CorvetteMike2024's Avatar
Received 2,000 Likes on 836 Posts
Default vette
Heres a good book to help you diagnos smog issues
Old 05-14-2009, 09:47 PM
RandyJ75
RandyJ75's Avatar
Thanks Mike, but I have it. Just looking for some other ideas.
Old 05-14-2009, 10:09 PM
GKK
GKK's Avatar
High NOX levels are directly related to the EGR delete as mentioned earlier.
The EGR valve lowers the combustion temperatures which, when removed is why the NOX levels were higher than allowed.
Each State has different emmision standards which is why some who have removed the egr have still passed.
Old 05-14-2009, 11:19 PM
kab3
kab3's Avatar
Randy,
Gotta believe it's the EGR delete, is this the first test without it? Did you discuss this with the chip guy to find out what changes he made to compensate for the EGR delete (i.e. richer mixtures, etc.)? Was the test done at idle or on a dyno?
Maybe trying to get the engine to run cooler (lower temp thermostat) would get you through the test, worth a try. Gotta keep as many of these charcoal ones going as we can.
I've got a pretty much stock setup (cat back exhaust only) and my NOx was good last test (about 13% of the allowable at 15 mph & 9% at 25 mph). I believe the EGR passes more at the higher speed.
Kab3
Old 05-14-2009, 11:49 PM
RandyJ75
RandyJ75's Avatar
The reason the EGR was deleted is because it set a code after the new exhaust system was installed. Everything was fine w/ it before the change, it seems that speed density cars need a certain amount of back pressure for the EGR to work correctly, so I really had no choice. That is the reason the car has a custom chip, to delete the EGR.
Old 05-15-2009, 12:12 AM
Benny42
Benny42's Avatar
Sorry, i mis-read. Hope you get it in line. Where is your base timing set?
Old 05-15-2009, 12:45 AM
jeffp1167
jeffp1167's Avatar
to run the egr without chip mod's just run its vacumn line straight to it from the throtthle body with a restrictor the valve only needs to open a bit to drop those numbers.
Old 05-15-2009, 07:09 AM
TJM
TJM's Avatar
Deleting the EGR is the MOST likely reason for the "Fail". Right out of the book, problem #3 of 3
This is the purpose of the silly thing.
This does not sound at all like a chip issue. If it set a code it was likely the Temp Indicator The little gizmo that goes into the EGR tube, right as it enter the intake.
Without EGR, on a basically stock motor, you could be getting a good bit more knock, and may run hotter, & FAIL Emissions!!!
TJM
Old 05-15-2009, 07:32 AM
jeffp1167
jeffp1167's Avatar
speed density does not have that heat sensing gizzmo
Old 05-15-2009, 12:29 PM
steven mack
steven mack's Avatar
It's the egr plain and simple.
Old 05-15-2009, 02:17 PM
bjankuski
bjankuski's Avatar
Thanks, Randy
The problem is the lack of EGR, you may be able to pass the test by retarding your timing, lowering the water temperature to reduce combustion temperature, or running a higher octane fuel that may burn cooler at low loads. If that does not work you may be forced to put the EGR back on to pass the test.
I just did a little research and a failed catalytic convertor is also listed as a possible reason for high NoX readings, you may want to check into this a little more.
Old 05-15-2009, 02:27 PM
SunCr
SunCr's Avatar
Might be/Should be - but the 3 way Cat along with EGR scrubs up about 60 to 70% of NOX emissions and if the knock sensor chimes in, it retards timing and fattens it up. That shortens the life of the CAT. Looking at the HC and CO numbers, it doesn't look bad, so hopefully reconnecting EGR makes it pass OR if these are idle numbers and not cruise, it is the CAT (and it's possibly lean) because EGR isn't doing anything at idle. Otherwise, without a scan, you don't know what it's doing and scanning it under all possible conditions isn't an easy task, but you might just run one to narrow it down.
To So My car failed Emissions...
Old 05-15-2009, 02:34 PM
rlane5
rlane5's Avatar
Sometime pulling a little timing out will help emmission,
Randy
Old 05-15-2009, 06:51 PM
steven mack
I have passed emissions after failing by retarding timing and adding two cans of Dry Gas additive to the gas tank. Just be careful not to retard timing to much or the other numbers could go up.
Old 05-15-2009, 11:14 PM
Benny42
Benny42's Avatar
Try a few gallons of E85 in the tank when you test. Too
often WILL kill your Multec injectors, but you you should
slide thru the test. benny
Quick Reply: So My car failed Emissions...
