Thread lock on Rocker studs?
Are you supposed to use it? If so, what kind? I will be putting my rockers on my heads today. 1.5 3/8 Harland Sharpe on AFR 190. Any other tips? :cheers:
Re: Thread lock on Rocker studs? (dtorc4)
No thread lock on the rocker arm nuts. If you were replacing your studs, then I would use it on the studs where they go into the heads, otherwise no.
